Side Piece Racing
Old 04-16-2012, 08:37 PM
  #271
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by syndr0me
http://www.hobbywing.com/product_show.asp?id=276
That sure looks like a 25x25 fan. Could be ripe for replacing with something good.
could be. i gotta research those super small plugs. similar ones appear on the lrp speedos too.
hanulec is offline
Old 04-16-2012, 08:42 PM
  #272
syndr0me's Avatar
Trader Rating: 32 (100%+)
Yeah, I've been looking at that too. They seem to be differentiated most often by the pin spacing. I'll measure the one on the stock fan when it shows up. I don't have the LRP connector to measure.
On your fans, have you ever considered using a small dab of something like hot glue to keep the wires secure in that groove? Wires breaking off are what almost always kill my fans.
syndr0me is offline
Old 04-16-2012, 08:56 PM
  #273
hanulec's Avatar
i generally route the wires through one of the screw holes when i chassis surface mount. i might need to look into something else for ESC mounts.
hanulec is offline
Old 04-17-2012, 03:07 PM
  #274
hanulec's Avatar
All of my Nikita outdrives have just been bought out from a new friend in Slovakia.
I may have some in a secret vault somewhere. Ill update you all here when I know more...
hanulec is offline
Old 04-17-2012, 04:37 PM
  #275
Buckaroo's Avatar
Around here, we all use a tiny dab of shoe goo.
Buckaroo is offline
Old 04-17-2012, 05:48 PM
  #276
Team EAM
Trader Rating: 79 (100%+)
You can make out that Royalty check to Eric Anderson
EA
EAMotorsports is offline
Old 04-17-2012, 07:12 PM
  #277
hanulec's Avatar
EA
Hell yes
You'll hopefully see something that interests u in the mail soon...
hanulec is offline
Old 04-18-2012, 07:07 AM
  #278
Team EAM
Hell yes
Sweet! At least one good thing came of my trip to Poland other than having a blast!
EA
Old 04-18-2012, 12:39 PM
  #279
ASM
ASM's Avatar
Trader Rating: 30 (100%+)
I put the first runs on my new fan this past weekend and they worked great! It isn't all the way "Florida hot" yet - but so far I'm very pleased. Thanks
ASM is offline
Old 04-18-2012, 12:45 PM
  #280
hanulec's Avatar
Sounds great!
What electronic package are you running?
hanulec is offline
Old 04-22-2012, 06:26 PM
  #281
hanulec's Avatar
I just wanted to let everyone know that I've been able to get a few more Nikita Outdrives back in stock. These are the last of the "V2" outdrives that support 52mm long drive shafts, so get them while they are still available.
There is another manufacturing run of Nikita Outdrives on the way... but the design has changed slightly again. The focus isn't on supporting 52mm dreive shafts, but bringing back the initial ultra durable design and enhancing it to reduce the load on the spool drive train by having the drive shafts at a different rotation angle - 90 degrees apart from one another. I'll provide more info on this once the production units arrive and are track tested.
hanulec is offline
Old 04-23-2012, 08:09 PM
  #282
hanulec's Avatar
Ran the Seis Fan sweat shop tonight to ensure there won't be any shipping delays.
Got some expected news from my machine shop -- they are late again! Was hoping to receive new Nikita's today, but it looks like they will be delayed until at least May 9th. Joy
hanulec is offline
Old 04-25-2012, 09:04 PM
  #283
hanulec's Avatar
I wired up two Seis Fans into a single Terry Servo Plug tonight in my new Photon EX.
This is the first time I'm running two Seis fans off the same receiver plug. I'll let everyone know how it goes. It sounds really good on the bench...
hanulec is offline
Old 04-27-2012, 09:44 PM
  #284
Super Moderator
Slo_E4's Avatar
Trader Rating: 62 (100%+)
I have a question. If I am using 50mm shafts with Nikita's, I should have a 1mm shim in between the axle and the outdrives? So the shaft sits a little deeper? Or should I just absolutely put 52's on?
Slo_E4 is offline
Old 04-28-2012, 03:08 AM
  #285
hanulec's Avatar
The Nikita outdrives are longer than XRay stock so that shims are not required.
hanulec is offline
