Pro-match Batteries
#1336
Cool, thanks man! I know the guys will appreciate it.
#1337
Whats a "Gentlemens" Club ???....I wouldnt know...Im no Gentlemen...LoL....
Vegas = Fun = Hangover = Gambling = $0.00
-EG
-EG
#1339
LOL @ rctoyguy......yeah we get them occasionally.
#1340
promatchrcr - Isnt there a "Sammy's" in Birmingham ???....Thats around your way rite ???
-EG
-EG
#1341
Yes sir... It is on the other side of town...I can be there in about 20-30 mins max.
#1342
What does the Smart Tray 2 take the battery pack down too? Do u recommend using it after I run the battery?
Any info would help...
#1344
Nice Logo EA. That will look good on the hood of my car.
#1346
OK - what's the trick? What kind of decal paper do you print on to use on car bodies? Or is this a "print a photo and put it inside the body" kind of thing - has anyone done photos in bodies?
I realize this is FAR from a battery topic, but we don't appear to be overly strict around here....
#1347
Excellent results can be obtained by following these guidelines. After using the packs you need to determine if they are completely discharged or not. If you are not going to race the packs again for more than a week you should put at least 10 minutes of charge (at 4-5 amps) back into them. See footnote below** Store the packs until the day before you are going to use them again. The day before you use them discharge them down to .9 volts per cell (5.4 volts for 6 cells and 3.6 volts for 4 cells) and then place them into an equalization tray*. Leave them in the tray overnight and then right before you charge them up remove them from the tray and start charging.
**Footnote: The longer you plan to not use the packs the more charge you should leave in them. For long term storage (more than 30 days), I would completely charge the packs before storing them. Also expect some false peaking problems of these cells after long periods of inactivity. This problem should correct itself after one or two uses.
*Not all discharge trays are alike. We recommend the use of our tray as it has a diode built in to it prevent over-discharging.
#1348
The Smart tray takes them down to about .9 volts for EACH cell. I absolutly love mine. Need to buy more.
#1349
#1350
I know I have seen glue made for using photos inside car bodies (before paint), and I thought I had heard of printing graphics on some sort of decal paper... Back in my model RR days I know folks did this, and I thought I had heard of doing it for RC applications.
I wouldn't expect to rival the work done by professionals - just curious how it would work - IF it would work - or if anyone here has done/tried it.
