Team Hurricane Motorsports
Old 07-12-2005, 01:49 PM
  #1801
BJohnson's Avatar
Hey Guys - The Brand Spankin' New Web Site should be up and running in the next day or two. You will be able to order all the 3700's your battery box can hold. We are also getting in 8 more cases of 3700's the middle of next week. So if we sell out right away, you'll only have to wait a week or so for more.
I will be at Trackside Sat. and Sun.
Thanks - Brad
BJohnson is offline
Old 07-12-2005, 03:26 PM
  #1802
Juan Valdez's Avatar
Thanks - Brad
Good news! I'll be sure to keep my eye on the website so I can grab some right away.
Juan Valdez is offline
Old 07-13-2005, 06:42 AM
  #1803
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
Keep up the good work Brad. The new cells look awsome.....
Matt
Matt M. is offline
Old 07-13-2005, 03:41 PM
  #1804
wolfden's Avatar
how do the new cells compare to the 3300's for runtime and voltage?
wolfden is offline
Old 07-14-2005, 08:19 AM
  #1805
Trader Rating: 42 (100%+)
sneek a peek.
Nexus is offline
Old 07-14-2005, 09:17 AM
  #1806
Kevin K's Avatar
Trader Rating: 32 (100%+)
They have longer runtime about 440 to 460 and the voltage is also higher most packs are looking like they are in the 1.18+ range.
Kevin K is offline
Old 07-15-2005, 06:35 AM
  #1807
Euge's Avatar
sweet! looks good!
Euge is offline
Old 07-15-2005, 10:52 AM
  #1808
Switch Blade's Avatar
yo, i have a question. Would the hurricane gold brushes be usable for three runs? Like would they provide the same power if I ran them for 2 qualifiers and a main, or are they only usable for two runs to get the best performance?
Switch Blade is offline
Old 07-15-2005, 10:56 AM
  #1809
RCGaryK's Avatar
Brad, you've got a PM
RCGaryK is offline
Old 07-15-2005, 02:15 PM
  #1810
Kevin K's Avatar
Yo.....Yes they would be fine for 3 to 4 runs. I would suggest that you cut the com every run and use the Hurricane Red Com drops...the red stuff helps brush life and adds some power. Just make sure that the brush isnt burnt and discolored at all.
Kevin K is offline
Old 07-17-2005, 04:03 PM
  #1811
Hey, Ill try using them then. I have a lathe so it works out very well, and just one more question to add, what is the difference between the two comm drops that hurricane sells?(i believe they sell red and blue?)
thanks
Old 07-17-2005, 05:39 PM
  #1812
Kevin K's Avatar
Yes Hurricane offers 2 type of com drops. The Blue Thunder is for Brush break in and the Red drops are for brush life and added power.
Kevin K is offline
Old 07-17-2005, 09:19 PM
  #1813
Hey...im sorry for asking all of these questions(i think this is it), but how long is needed to properly break in the hurricane brushes? Like for 4499's trinity said 600 seconds at 2 volts, and for trinity cross cut brushes, i was told by a racer to break them in for 500 seconds at 2 volts.
Thanks again
Old 07-18-2005, 07:23 AM
  #1814
Administrator
Matt M.'s Avatar
i break mine in at 2 amps witha fan for 200 sec..then run them...i am not sure if that is what the rest of the team does but it is what i do..
Matt M. is offline
Old 07-18-2005, 10:19 PM
  #1815
Kevin K's Avatar
Thanks again
You dont need to break them in for that long....you are using up the brush running it that long. Like Matt said.....2volts for 180 to 200 seconds is good then just spray it out and put some RED drops in and go run.
Kevin K is offline
