Team Hurricane Motorsports
#1546
Originally posted by Kevin K
JDXray....For a sedan I would run with the gold brushes with a monster I would use Red/Green or Red/Red spring combo and a hole in the face of the brush. I break them in with Hurricane Blue Thunder com drops at 2 volts for 180 seconds with out a fan....if you use a fan break in the brushes for 120 seconds. Then spray the motor out and relube the bushings and put two drops of the Hurricane RED com drops on each brush and go run it.
I did mine like this:
Hurricane Gold- full face
centered armature
break in no fan- 2.0v 300sec
Purple/Red
Bushing Lube
Matrix RPM Blue
With good results : 9-10amps 2.0v
#1547
Trader Rating: 32 (100%+)
Well not every Turbo 30, 35 or GFX reads the same but on average you should see with out a fan at 2 volts an 8 to 10 amp range.....with a fan you should see 9 to 12 amp range if not shut it off(with older 30's and 35's) after you have sprayed it out. Even if it doesnt show high amps that doesnt mean that that motor isnt strong. High amps mean a number of things. Last weekend I raced a motor that was only pulling 6 amps at 2 volts and I was able to TQ over many top drivers including the Cleveland stock winner. And that motor was great on the track.
#1548
I have noticed, some low amps motors sound okay, and the some really high amps are quite.. I dont get motors sometimes.
I am stilling playing around with that monster with Hurricane, I might make the POS side alittle stiffer and align hoods (Which i havent done yet, lol) All trial and error
Jon
#1549
It looks like you might be breaking the brushes in for too long of a run. There isnt really any benifit to going past 200 sec IMO. That just heats up the brush before you even get to run it. Also the Purple/Red spring combo is a little heavy but some motors need that. We mainly run that combo on the ROAR stocks and the BS motors but we have used it on monsters from time to time. Everything else looks like it should.
#1550
I always here to go 300secs but thats what i hear.
Is hurricane coming out with another brush or staying with 1?
#1551
Originally posted by JDXray
Ya i dont understand that, low amps means there bad or good? Because i have had some stocks go really low but are they good?
Jon
Jon
#1552
At this time Hurricane only has the Gold brush but it does work well in stock and 19t. Maybe with more work there might be another brush but nothing new at this time.
#1553
Jon
#1554
Cool....yeah let us know what you find out.
good luck
good luck
#1556
Well it depends on the 19t motor and if its locked or adjustable? For the Reedy flame 19t I do everything the same as I do for my stock motors but I run the stock springs. With 19t I find that I go though the brushes more often then with stock. Its been a while for me using a C2 or anything other then a Reedy 19t. I kinda remember that we used Purple/Purple or Purple/Red on the springs and Used a hole and or narrowed up the brush.
#1557
#1558
No problem...good luck.
#1559
Hi Team Hurricane Motorsports,
Do you have any motors available?
Thank you
Thank you
#1560
Thank you
Thank you
