BMI Racing Discussions
#2926
Thanks....
I got that name from my girly. Cause I can put in as much work as a whole pit crew....
but that sets me up for.... In under 9 seconds
#2927
"He's in! He's out! He's asleep"
"that was a good one and in only 12.3 sec"
j/k
Rob
j/k
Rob
#2928
you got the idea!!
#2929
i hope your not saying what i think your saying....12 second brother?
#2930
uh...no.... It only takes HER that long
#2931
droop
o.k. fellow racers, have you ever had a math question that actually had two answers. well the droop delima actually has two answers because ther are at least two ways that racers check/change droop. first if your running rubber or foam tires then check your droop using the blocks under the chassis then measure the distance between the hub and setup board or table. presto you have your droop setting and it will not change unless the scwews dig into the chassis or a severe wreck that might have tweaked something. The second option is when you run foams and you check the droop by setting the chassis on the droop blocks and measure your droop by barely leting the tires touch the surface of the settup board, then with tire wear the droop setting must be changed or at least checked between rounds. but beware your tires must be exactly the same diameter or you will develope a tweek either on throttle or on brake depending on which end the problem is on.
As for the remarks about B.M.I. products I have only one testimonial. I have been racing my factory xray for about a month, which is an awesome piece straight out of the box, then I put my brand new B.M.I. chasis and top plate on, and in the first week out with it took three tenths of a second off of my best pre vious lap times. I guess when you have a company that soley consentrates on one or two aspects or a car that has hundreds you will eventually end up with a superior product.
Bill Connard
Team B.M.I.
Bill Connard
Team B.M.I.
#2932
how much is the ntc3 chassis from BMI?? and any coments on?
later lazy
later lazy
#2934
bmi products
re:bmi products
if you havent seen jasons work do yourself a favor and take a look at one before buying someone elses chassis kit.after having three different companies kits i can honestly say jasons are second to none.same results for me as previous post,lap time dropped and are much more consistant.i believe this is due to the stiffness of his chassis as you will immediately notice the car feels exactly the same every corner every time(assuming the car is setup correctly),torque steer is a thing of the past.also NOBODY finishes the chassis as nicely or completely as his,no need to go and spend hours filling your new chassis.
#2935
The Best Sedan I have ever owned is now my BMI Pro4-PERIOD!!!
And that to me says a lot becuase have no tuning options for it yet-and its that good right out of the box.
Every bit as fast as my BMI eTC3 and as easy to drive fast and on the limit as the BMI Xray i have.
Ray
Ray
#2936
Registered User
OMG!!!!!! Connard finally figured out how to post on here!!!! Congrads Bill!! BB
#2938
#2939
i just got mine from crc they are nice.. plus they are on sale for like 18 bucks cant beat that.. the are made of like 4mm grafite very stiff
http://www.teamcrc.com/teamcrc.cgi
check the associated parts
most stuff is on sale i got the center shaft bearing cup to for 7.50 half price
