Fukuyama Batteries
#6647
Originally posted by Maj. Teeth
And all along, I thought I made you guys fast.
Dan
Dan
#6648
Re: Technical question about voltage and capacity
I do not know much about electricty and electronics; but,
aren't there componants which alow you to increase voltage, coils or transformers?
In circuit design can't you trade 7 volts/30 amps/8 minutes for say for say 8.5 volts/30 amps/ 6 minutes.
If this is the case you would think that since 3800mah have more capacity or more total amp/hours tan you need for stock racing, you could put a componant in the circuit which would give you more voltage.
This is actually a question that I've thought of as well. Unfortunately, the nature of a transformer doesn't make the idea very feasible.
A motor is basically a resistor that converts electical current into a physical force, by creating a magnetic field. So physics says that if current flow remains constant, an increase in voltage should increase power, as power = volts squared/resistance. The way a transformer works is that the current from the power source creates a magnetic field, which in turn creates a current on a different "wire". The drawback is that you need a varying current from the power source, hence the need to invert a DC power source into an AC source. This isn't an issue in large generating operations, as they are mostly AC anyways. So, to make the scheme work, you would need to invert the current twice between the battery and motor, and that equipment would weigh a lot.
#6650
Originally posted by Jon Kerr
Dan- I just got my Reedy Race packs in the Mail. I almost fell out of my chair. I can't wait to strap these things in. Thank you!
#6651
You have no excuse NOT to win right?
Dan
#6653
Hey Dan,
Got the awesome pack you sent me!
Thanks,
George
Thanks,
George
#6654
That's right. You going to be at the race?
Dan
#6655
Originally posted by stonedgti
Hey Dan,
Thanks,
George
Hey Dan,
Thanks,
George
Dan
#6657
I'll probably give you a call during the race to let you know how it's going.
Dan
#6658
Dan : When are you planning to release the GP 3700s ?
#6660
Originally posted by Grizzbob
I believe he's answered this one before, & that answer is they'll start selling them once they're approved by the major race sanctioning bodies(like ROAR).....
