Fukuyama Batteries
#5641
You've got it. Personally, I never run my packs twice in a day if I can help it. They do get a little faster but loose a little run time and I run mod mainly so runtime is an issue. If you're running stock, twice shouldn't be a problem.
Also I'd go witht the LRP comp Pro charger instead of the Novak. I like Novak but the LRP has the motor run in and the discharge if you need them.
#5645
Use the GFX to charge the fukuyama cells. They love that charger. If running stock, charge a 6 to 6.5 amp with a .04 peak detect, no flex charging or trickle and you'll really see those cells fly!
Running Mod, drop the charge to 5 amps to gain a little more runtime but keep the .04
