Fukuyama Batteries
#5626
Originally posted by jkerr0043
Carpet? What's that stuff? We get to race outdoor year around here.
Actually I do have a little announcement. I was picked up by Schumacher this week to run the MI2.
#5629
Originally posted by hawker
Anyone seen Anthony Yeung around? I've PM'ed him but no reply for about a week now?
Thanks Guys
Thanks Guys
Thanks for your message and I found that I did "Log in" after re-install my OS. I get your message now.
Check you inbox, Thanks !
Best Regards
Anthony Yuen
#5631
John - what's your opinion on the BMI chassis for the XRay, and have you used it on carpet? Have you compared it to the new XRay rigid chasis?
Rob
Rob
#5632
Rob
Rob
I've driven the BMI chassis on carpet and it's much better than the stock chassis. Not only is Jason's workmanship awesome, he does R&D and design changes with us, his drivers. This 350 chassis has the batteries moved .350" forward and closer to the centerline for quicker transition. BMI only buys the best Carbon Fiber. The CF that he uses has a grain direction in 3 directions, Front/Back, Left/Right and DIAGONAL, not like Xray's two direction (F/B and L/R). It's super stiff and never flexes. And his thickness is 3mm, very thick and he mills out holes to lighten it up without compromising flex. Combine this with his super stiff 3mm upper deck and you got yourself a awesome carpet machine, all for a very low price! His chassis is also lighter than the Xray, and cheaper. Jason stands behind his product.
Here's a pic of my Titanium colored 350 chassis.
#5633
Page 1
Hey Guys,
Let's keep this on page 1....
#5634
my fuku packs slept in the closet for half a year and i just dig them out and charge them yesterday, no false peak at all, all peak below 9.20V at 135~deg, and the punch is still there.
it's time to put a real work out for the packs for the winter season
#5635
Getting
I just purchased some Fukuyama Batteries recently and hopefully they come soon. I was wondering at what mv should i charge them at to get good punch.
I charge at 6amps and 35mv right now. Should i change anything?
Also battery maintence, probably been asked a million times. After race/practice run i should discharge at 30amps down to 5.40v and then try them until .9v right? Anything else i need to do?
Jon
Jon
#5636
check out the tech info at fuku's web site, it answers all your questions
#5637
Re: Getting
Jon
Jon
Run your packs once a day if you can, discharge to 5.4v and store them after they've cooled. (not on a fan) Tray them before the first charge of the day to .9v then charge. No need to tray after the run. Don't put hot packs in a battery case. I had a pack vent and ruin 3 brand new packs that way a while back.
#5639
JDXray -
You can adjust your peak detect based on the heat of the cells at the end of the charge. If they're peaked and around 110ºF you can increase your peak detect higher to get in the 120-130ºF range.
What charger do you have? Tray the pack to .9v/cell before your initial charge. Discharge them to 5.4v/pack @30 amps after each run and let them sit for 1-1/2-2 hours before the next charge. You can run them a 2nd time in the day and you'll find the chemicals will excite more and give you more punch. Do not run them 3 times in one day.
Thanks for purchasing Fukuyama cells. I'm sure you will find them fast if you take care of them well.
John
John
#5640
I am using a CE Turbo 35 GFX and LRP Pulsar Sport. (Might get a Novak or LRP Comp charger to replace the Sport)
Okay so run tops twice a day never 3 times. Tray before Charge and run. Discharge @ 30 amps after run, let cool for 1 1/2-2hrs.
I have always wanted to use Fukuyama but never got the chance to get to them, now i have. Thanks again guys
Jon
Jon
