Trinity D3.5 13.5T Timing
need help to adjust the timing, cant post it in the trinity thread.
from the endbell, it has the marking up to 40 but i can only turn it to the left at 20, couldn't go all the way to 40. it that correct?
i realized that when i hooked up with a team powers 1s xps esc at 0 timing, it was so slow
Trader Rating: 51 (100%+)
Hello Choisan,
On the back of the enbell there should be 3 screws un-tighten them all some times it binds up and it makes it hard to turn try that hope this helps
I personally don't follow the timing marks on the can. Always use a motor analyzer if possible as it will give you what the true timing is.
I use this method and with help of friend:
- install a battery.
- loosen the timing screw so you can rotate the endbell
- Turn the timing to down
- Now have friend hold the throttle wide open and you slowly start turning up the timing. (don't worry about sparks that may come off)
- keeping turning it up until you heard the get faster all of sudden
- lock the timing in place
- you should now be in the sweet spot and should only need to adjust a +/- a deg from there.
If you're boosting, please use an analyzer to make sure your timin isn't past 60deg when adding boost.
Good Information!!
