Shenzhen Surpass Tech Co. Ltd
#16
I didn't take any notes or pictures when I took it apart, I should have! I do recall the rotor having 12.3 stamped on it though, pretty sure?
IIRC correctly there is a number stamped on the pinion bevel of the rotor, is that typically a serial or part designation number and can indicate what rotor it is?
#17
12.3 is the diameter and the number stamped where the pinion goes is the part number. That's the number I would like to know.
#18
I took the pinion off and I think it wore away a number, but it appears to the C78125 rotor.
It must have said 12.5 on the rotor, I was going from memory. I see that part number is the 12.5 stock spec.
#19
Shenzhen Surpass Tech Co. Ltd Its really IRC correctly there is a number stamped on the pinion bevel of the rotor, is that typically a serial or part designation number and can indicate what rotor it is?
#20
Yup,
That is the same rotor as the one in the Stock Spec 17.5T. So far, that is the most powerful rotor I have tested. It even ousted the Certified Slot Machine.
#21
I am doing another practice session tomorrow to get it dialed in and will report back, didn't get enough time with that car this past Wednesday to get enough of a feel for it.
#22
I could tell that thing was strong when I pulled it out to shim the motor. I layed it on the table close to some tools and it sucked itself toward anything metal on my work bench lol
LOL...
I hated shimming that motor. Every time I pulled that rotor out, was a pain. A couple times, I used pliers because my fingers were getting sore. Especially when you're trying to line up the rear shaft with the end bell bearing and I'm doing this to 4 other motors. Check out WMH Racing. They have a motor servie tray that comes with a rotor removal sleeve. It's my new favorite tool when taking these motors apart.
