BANZAI Motors
#9811
Just got home from the Truck Race, it was fun, but i had a little bit of bad luck. I ran a 10.5 in the open mod class and i never felt like i was at a disadvantage because of my motor.
I have a 6.5 with only 1 run on it that i would like to sell if anyone is interested, just send me a PM. It felt great on the track, but it was a bit to much motor for me.
Thanks to Scott and the rest of the Banzai Nation for the help this weekend, and ill see ya around at club racing.
#9812
Puddle- We were running similar finals. I was at 5.12 running nimh but with the lipo I felt I could go 4.83 (up two teeth). With the car 200g lighter I could go up a couple teeth.
Just started running the 13.5 I think my sensor wire went bad but the motor came off cool running 5.89 FDR. (it was only 120) so I feel safe going up some more. It was only the third run on the motor though so I have some more testing to do. I had to do some tweaking with the spur gears though. (30/68)
I will figure it out soon enough!
#9813
Wow Puddle, way to go. Big Thanks to all the boys Down Under
I did a little testing this weekend with the 13.5 The Old Dudes were allowed to run 10.5's, but after being scolded by Fez, about being out of control we decided to run a 13.5. It ran great and I ended up at a 30/78 in a T4. 6.75 FDR. I did not give up much, if any at all, againist the 10.5s. I to will have to do some more testing, but the first test was good
#9815
I'll post some results on the Reedy later. I want to thank all the Banzai drivers for a great effort and not giving up. We might not have come home with the exact results that we wanted but it was not for the lack of effort TEN
#9816
Ya I didnt do so hot this weekend I only put it in one show....the 19turn main...
and I got 2nd in the stock B main and I Bq'd(tied for the A main in points but lost the tie breaker) and got hacked the first corner of the main and ended my race there.
But im not much of a truck driver anyways so I dont mind. Anyways thank you Scott for you help this weekend with everything and sorry we didnt get stuff done in the mains! But I will be at ocrc this weekend so I hope to see some of you guys there!
#9817
#9818
i ran mine at crcrc this weekend at 31/78 on my losi buggy. motor came off at 109 and speedo at 107 without the fan. geared it up another tooth but my nimhs are on their last leg . had hard time getting them to charge , they only set a week . but they are 4200 wc's. and they wouldnt cooperate. i got out my 3800's they been sitting for a year and they charged up after cycling them once. i finished fourth. now i just have to be patient for my xmas bonus to get some lipos , i just didnt have the voltage to get in the 19 second range but did run some 20.0 s. on my losi the fdr figures out to 6.11 , maybe not enough gear yet , till i get lipos bought i will leave it alone. i prolly could have set my drrs up also had it at four. next weekend i 'll set it to five .
#9819
If your batteries are not strong turning up the DRRS may not have much of an effect as basically this is like a current limiting setting. Lower numbers are more current limiting, higher numbers are less current limiting. IF you batteries are old with higher resistance they may already be putting out what they got. Just a heads up if you don't see much of a change. Also high DRRS settings can make the motor feel like a switch.
#9820
i could see it speed up in steps. it did keep me from sliding down the off camber we have on our track from overpowering it . LOL. although i did get one more lap in main then i have been getting. one of my buds going to loan me his new 4600 and lipo for halloween trophy race at crcrc.and bump it from 4 to 5 on the drrs. but as always thanks casper.
#9822
didnt think of that , i need to lower it right?
#9823
My motors were cold after 6.5mins racing. I could have really had another tooth or two on it but I was happy with the car, had enough legs down the straight as it was... I started with a 32 on it in qual's and went to a 33 in finals...
Considering it held the fastest lap around the track in 2wd stock for the weekend, it was damn quick for a 2wd.
Go Banzai Brushless!!
#9825
Im sorry Scott
