Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 01-25-2012 | 01:52 PM
  #4351
Default R/C stores
hi, im from the philippines, where can i find Tamiya R/C shop here in Singapore?
jeddicris is offline
Old 01-31-2012 | 02:30 AM
  #4352
Default Test
Test Post
cboerst is offline
Old 01-31-2012 | 09:45 PM
  #4353
Default Test Again
Sorry, guess I have to post a lot to be able to register for a race
cboerst is offline
Old 01-31-2012 | 09:47 PM
  #4354
Default Test
Again
cboerst is offline
Old 02-12-2012 | 06:39 AM
  #4355
Is the tamiya tt01 cheaper or the hpi E10?
Samuel Woo is offline
Old 02-17-2012 | 11:09 PM
  #4356
Default New to rc.
Hi,
I just bought a TT01E RTR. Any recommandations to make it a drift car or a racing car? Which is more fun?
I am a noob when it comes to all the specs of the cars. What should i look out for in a rc cars? I read some of the posts and it doesn't seem helpful to me in understanding more for the car. It seems that TA05 is a better car than TT01.
Can anyone help me in understanding more about the specs inside? Like the gears, motors and cambers, toe-in something like that?
Thanks!
braker is offline
Old 02-18-2012 | 12:48 AM
  #4357
FT's Avatar
FT
Download this and it will explain everything clearly - XRAY T3 Setup Book
Although the setup guide is not for TT01 in specific but it will give you a general idea about setting up a R/C Car.
The TT01 can be made into drift simply by changing the Tires to 'Drift-Type'. For further drift performence, you can adjust the suspension characteristics via changing shock springs or upgrading to shocks which can adjust it's dumpening effect. Locking of front or rear differentials will also significantly change the drifting characteristics. There is no real specific setup for the TT01 to be operated on all tracks however I will explain further if you would like to know a my Drift Setup for TT01 which performs generally well on all surface and conditions.
For Touring(Race) setup, you do not have to bother much as the TT01E is built for stock racing and further investment to upgrade it pose no significant benefits, the money spent would be a better investment if you were to get a better car instead such as the TA05 or other well known brands and models for Touring use.
FT is offline
Old 02-18-2012 | 02:22 AM
  #4358
Thanks for the guide, it may take quite awhile for me to finish understanding every part of the car. Haha!
But the guide does not have the esc, rx and tx and the servo. I am using the stock rx and tx and this seems to always have interference by other people who uses the same controller as me. Should i change the controller or must i change the receiver and the controller together?
braker is offline
Old 02-18-2012 | 02:44 AM
  #4359
Talking Servos.
Why when i search on internet for servos they always put kg? sorry iam quite to rc
B4tMan23 is offline
  #4360
Pls reply
B4tMan23 is offline
Old 02-18-2012 | 03:24 AM
  #4361
adrictan's Avatar
Bec we Asians understand KG rather than LBs. U can always do yr own conversions using Google.
adrictan is offline
Old 02-18-2012 | 05:27 PM
  #4362
so it means the weight right?
B4tMan23 is offline
Old 02-28-2012 | 06:16 PM
  #4363
Default Engine servicing and others on old HPI MT2
Hi all RC veterans,
I had an old HPI MT2. Looking to see whether it is worth servicing as I had not play the car for some time, flywheel is stucked plus other problems. I dont have the tools to open up the engine to clean it, sigh.
Any reasonable servicing with great service out there? I had ask some shops but thought it would be good to get an independent veteran here to take a look at my car instead.
Any good advice? I would like to get this old babe of mine to start firing again. Thanks.
jamjammer is offline
Old 03-19-2012 | 03:10 AM
  #4364
Default Looking for help on RC electrics
Hi Rc Enthusiasts...
Im new to rc cars though i hv been in rc planes for years. Am looking to get an electric on road car, Am lloking for something slightly above entry level/average and also with possibilities of upgrading. So could you guys recommend me of some gd cars and also maybe which shops i could go and get these recommended cars. Also and roughly how much im looking at for the car as a RTR kit.
Also hope you guys could recommend me a gd enough TX with e latest functions. Hope to here from you guys soon.
Cheers
wickkerr82 is offline
Old 03-24-2012 | 01:39 PM
  #4365
luke71933's Avatar
So,
I am new to offroad racing , what should i get form the two of the above, I do not want to waste my money. So, I would like to know if i am going to waste my money on caster cause its a bit cheaper than the losi.?I will not race at first I will just drive for fun at the local track, i will afterwards when I get good race.I only have funds to buy the caster right now should i buy it or wait till i get the money for the losi?
Luke
luke71933 is offline
