Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 09-08-2010 | 07:41 PM
  #4051
greenruby79's Avatar
Hi Rlau99, thanks for the info bout the battery. So if i wana buy one for my rc car i should get a higher mAh and also higher C. But can i use it with stock motor or i need to upgrade it to compensate with such power? Also i serach that LiPo battery are in the rage now for rc cars, so do you guys have any recommendation?
i guess its better to get aftermarket charger as it will cut down on charging time thus more playing time. Thanks again...Cheers.
greenruby79 is offline
Old 09-09-2010 | 03:34 AM
  #4052
Default What happens when electronics get wet??
Hi all i was wondering what happens to your electronics when they get wet?
Thanks.
LachlanWinten is offline
Old 09-09-2010 | 04:21 AM
  #4053
Thanks.
first it will spoil and if you are lucky, they will still work, just that might have to change it real soon
rgregious is offline
Old 09-09-2010 | 05:17 AM
  #4054
will it just stop cause i ran my car on wet ground yesterday and charged it and then it went for like 2 minutes then it was like it had not been charged?
Old 09-09-2010 | 06:19 AM
  #4055
did you clean it immediately after it hit the waters?
if you do, it might save the electronics
i'm not very sure about your car's condition but i guess if its performing abnormally, i think its busted
Old 09-09-2010 | 11:29 AM
  #4056
Rlau99's Avatar
Batteries with higher mAh & C rating is like having high grade fuel but you will need a good engine (ESC & Motor) to maximize its potentials.
For most stock ESC & motor (mostly brushless type) Nimh batt should be good enough. High mAh will give you longer run time.
Most upgrades are brushless system, high mAh & C batt will be needed to maximize the brushless power (high speed).
There are lots of Lipo batt in the market now, depending on your budget & application (bash or race) you will then decide which grade of lipo is more suitable.
Rlau99 is offline
Old 09-09-2010 | 07:48 PM
  #4057
1716's Avatar
hello , i'm new to RC and got a question on the gear things. i got a TT01D and was just wondering what is the best combi for the spur gear and pinion? i read through the forum and they recommend 58t/23t and 55t/25t?
1716 is offline
Old 09-13-2010 | 11:55 PM
  #4058
Default Need advice
hi, need advice from pro here.
whats the diff between lipo and nimah batts?
Is there charger good for both? -- Prolux digipeak, 1-14 cell
Whats the pricing like for new and used?
iamxd is offline
Old 09-14-2010 | 03:27 AM
  #4059
Lipo last you longer than nimh batteries, and lipo are slighty harder to maintain, T-15 plus will allow ue to charge both lipo and nimh
Old 09-14-2010 | 04:03 AM
  #4060
thanks bro, taking tat into consideration, how abt the above charger model( Prolux digipeak??
iamxd is offline
Old 09-14-2010 | 05:56 AM
  #4061
that one cannot charge lipo
Old 09-16-2010 | 07:20 AM
  #4062
hi all fellow Singaporeans,
Considered noob here since the last time I touched RC cars was like 16 yrs back. I've totally lost track of RC news and tech but recently, I have been trying to get my 7yr old son on RC car as he really loves cars.
I have done some research but I'm still at a lost regarding entry level EP road cars.
I'm considering the following choices:
Tamiya TT01
HPI E10
Kyosho Faser/Pureten series
Kyosho Mini-Z AWD
HPI Micro RS4
In terms of hop ups/aftermarket mods, which models here have the most "support" locally? I only know 1 shop for each of the brands above, Tamiya (Stargek), Kyosho (Toykar) and HPI (Tai Sing). Are there other shops too?
I've a preference for either mini-Z and HPI micro RS4 due to the size and hence the possibility of playing indoors but the build is unlike the 1/10 series that works more like real cars, which would be a learning ground for my kid.
Noak is offline
Old 09-16-2010 | 09:20 AM
  #4063
Tamiya TT01
HPI E10
Kyosho Mini-Z AWD
HPI Micro RS4
TT-01 will be considered the better one as the hop-up and replacement parts are easily avaliable. local hobby shop that sell many parts would be at orchard plaza level 2, swan model land and trading.
Old 09-16-2010 | 10:12 PM
  #4064
hi guys I'm from Brunei. Wondering is there a GS racing dealer in Singapore? I'll be there for a week or so. Thanks!
cheapskate.brok is offline
Old 09-17-2010 | 08:16 AM
  #4065
Thanks! I'm surprised that Tamiya is still the better choice as back in my time, the craze was for the HPIs'.
Noak is offline
