Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 11-18-2009 | 09:12 PM
  #3751
adrictan's Avatar
Originally Posted by roychan69
Nail Polish Remover is actually Acetone; you can get them in most departmental store or Watson...
I believed you're using it to removed your glued tires...?
There are better ways than using Acetone.
I'm using nail polish remover already. I don't have oven to bake leh.
adrictan is offline
Old 11-19-2009 | 02:16 AM
  #3752
roychan69's Avatar
'Oven Method' don't required Acetone.
Try the 'Boiling Water Method', boil it for about 10-15 minutes; before it cools down, wear a thick glove and you could basically pull the tire out from the wheel...
roychan69 is offline
Old 11-19-2009 | 02:30 AM
  #3753
SuperEk4's Avatar
My god! U dun know there's boiling method? U want to bake tires aah? Lol
SuperEk4 is offline
Old 11-19-2009 | 02:56 AM
  #3754
roychan69's Avatar
Actually his 'baking method' is alright also.
Old 11-19-2009 | 03:24 AM
  #3755
SuperEk4's Avatar
After that his mum will kill him lol.
SuperEk4 is offline
Old 11-19-2009 | 03:45 AM
  #3756
roychan69's Avatar
No... His mum will bake him too...
Old 11-19-2009 | 10:57 PM
  #3757
Where is a good place to run/bash M-chassis in SGP?
leongkc is offline
Old 11-20-2009 | 03:00 AM
  #3758
roychan69's Avatar
What you mean M Chassis...???
Old 11-20-2009 | 03:31 AM
  #3759
Nov's Avatar
Nov
Tamiya M-chassis...M03, M05 etc...
Can run at BK's track at Bottletree Park...
Nov is offline
Old 11-20-2009 | 03:48 AM
  #3760
SuperEk4's Avatar
Btw must pay one lor, mon close tue to thur $12. Fri to sun $15. Hv charging point, off road n crawler track.
SuperEk4 is offline
Old 11-20-2009 | 03:54 AM
  #3761
roychan69's Avatar
Oh I see... Don't know about that hahaha...
Anyway SuperEK4 already answered him...
Old 11-20-2009 | 06:16 AM
  #3762
Is it crowded on weekdays? I have quite a number of days of leave to clear in Dec, thought of going down and have a look...
leongkc is offline
Old 11-20-2009 | 09:03 PM
  #3763
Ivan Hng's Avatar
Originally Posted by Ivan Hng
To all the bros out there, I got a bit of a problem right now. Help and advise needed.
I keep on twisting and snapping my drive shafts. Is there any way I can custom my drive shaft with something much more durable? eg spring steel
The one I am using now is from HPI and its made of steel. Every time I twist one, the damage to my pocket is about $30 bucks.
Or does anyone one know where can I get a replacement which is of the same or similar dimensions? (Pics and dimensions below)
All comments and advice are welcomed and appreciated.
Thanks in advance.
Found! Thanks Sia!
Ivan Hng is offline
Old 11-21-2009 | 04:40 AM
  #3764
roychan69's Avatar
Found! Thanks Sia!
Good... Long told you to look for Mr. HPI...
Old 11-22-2009 | 06:10 PM
  #3765
alantan_74's Avatar
No problem.
If you tried your other 3 'normal servos' that was stock from your other cars and the twitching is still there; perhaps you should loan a better quality one from your friend to test it out.
It should not be your radio problem though.
Hi,
Nw i have change both servo to towerpro 995 and the problem still the same.
1) When i turn the steering to either left or right the throttle servo will twitch.
2) The throttle servo have sound(Mean can hear e motor run but the gear not moving but after a while is stop.
3) Can it be the receiver problem??
Is truck giving me headach,
Can any bro here pls advice as i change what i think so change.
alantan_74 is offline
