R/C Stuff Selling
selling mini-z AWD
-item gd in condition seldom play coz really no time due to work
-come with orginal Box ,TX,RX car cover(R32)
-item addit include WRX STI 2007(blue),trueno AE86 (car all come with its own casing )
-come with dift tyre set one use (another set NEW)
- normal Tyre STill new (coz onli use for drifting onli)
-Come with LED set fix in too
CAr set with box @ $350
Car cover $120 ( 3 cover abv mention)
interested pls sms /call 97950469 thanks...
3racing DF03 Front graphite shock tower - $24
TopCAD DF03 rear graphite shock tower - $25
Tamiya DF03 Aluminium One-piece Propeller Cup Joint - $8.50
TT01 Turnbuckle Tie-rod Set - $6.50
Lightweight aluminium heatsinks - $5 each (2 pcs available, brand new) Good to use on ESC or other hot devices.
All brand new in package
Items may be transacted at BK weekends or other locations at my convinience. Call or sms to 93669148.
CVA shocks with springs 4 pcs - $5 (used) condtion 8.5/10)
Ansmann ACX-2 wall charger. Plugs directly into wall socket. charges 6 cells (7.2v) Capacity 1400mah to 3500 mah. 6 hour safety timer. Used less than 5 times. Asking $25
WTS:
NIP Tamiya BMW Z4 with lightbuckets and body accessories, $56
Tamiya PS-23 Gun metal spray unopened $6
2 Tamiya Aftermarket 1 piece differential Thrust ball, $10
GP 3700mah, Peaking at 3500 - 3600mah, with a lot of punch for drifting. Will charge for you to test. $50
IB 4200 side-by-side, Peaking at 3600mah, Can use for bashing $25
Both Battery at $65
1 Sets of PVC Tires (unused), 1 set of $3
HPI shock spacers, $3
All size, 3 in total
Kawada Duralumin 25T 48 Pitch Pinion Gear, $6
Yokomo Ring Gear / Drive Gear Set, $8
Yokomo GRAPHITE Front One-Way Gear Set $10
Yokomo top foam bumper holder (new) $6
26.995AM crystals set for Tx & Rx, $10
1 Sets of PVC Tires (unused), 1 set of $3 Buy now!
PM or SMS me at 81009203
Both Battery at $65
WTS:XB TT01D drift spec NISMO Coppermix Silvia with TT01D LED Lights, whole set RTD
Comes with stock TX & Rx,
NISMO Coppermix Silvia Chasis with LED light kit
Tamiya Sports Tuned Motor
electronic speed controller (TEU-101 BK) with Servo
Alu Heat Sink,
PVC tires +wheels, and a set of 4 brand new tires + wheels (which comes with the package)
upgrades: Red harden springs, Alu propeller Shaft, blue foam bumper, new 55T/25T gears and new Alu bumper stopper plate.
Simply Just Plug in battery & Play, No need to buy anymore stuffs.
Bought it 3 months ago, thinking of upgrading.
Played less than 10 times.
The above set comes user manual.
Selling The Above For Only $300. If this price is met, i will include a IB 4200maH battery stick.
Self-collect @ Simei Area.
call or sms me at 93372433
Alu Heat Sink,
Selling Team Magic G4S kit with some hopped-up $150
Interested SMS me at 81139780
self-collect
self-collect
Hi.
1) Used Rechargable batteries for TX.
8x GP1600 AA rechargable batteries.
Selling for $20
2) Used Rechargable batteries for your DIY light.
4x GP1000 AAA rechargable batteries.
Selling for $20
All battery in great condition.
AA are my spare TX battery, charged for a few time onli.
AAA are very new, charged a few times for my DIY light kit onli.
PM or sms mi at 98291044.
Selling for $20
Selling for $20
Hi.
Used but VERY GOOD condition wide pitch pully for TA05.
1x wide pitch pulley for ball diff (black) @ $9
1x wide pitch pully for Front One Way/ Direct Coupling (black) @ $9
If can deal fast for both, $15 for both.
TRF 416 for sale
box and manual all intact
all parts that are spoilt have been replaced....
pls offer ur buying price....
anything below $418 will not be considered....
M11 for sale
comes with standard 40mhz module and receiver. You will have 2 frequency to choose from.--->>> 40.71 or 40.73 ,
speedmind bag
box and batt holder.
selling at a price of $363neg
if you are will to top up for 2.4ghz sanwa module and receiver i have 1 for sale at $164
very special price will be given if take both....
M11 for sale
speedmind bag
I gt a ta05 rolling chassis which i is tune to drift only 4 sale. condition is 9/10. juz some normal scratches at the bottom of the chassis =)
Tamiya Parts
Tamiya FL Coated 5mm Aluminum Ball Studs whole car
Tamiya Low Friction 5mm turnbuckle ends whole car
TA05 Sway Bar kit (front and rear)
TA05 Carbon front shock tower (front)
TA05 Carbon shock tower (rear)
TA05 46mm Universal drive shaft (front)
TA05 46mm Universal lightweight drive shaft (rear)
TA05 Aluminum Racing Steering Set
Tamiya TA05 Lightweight Aluminum Servo Mount
Tamiya TA05 Carbon Steering Plate (w/bearing & hardware)
Tamiya TA05 Carbon Battery Plate Set
Tamiya TA05 Aluminum Side Brace
Tamiya TRF415 Aluminum suspension blocks x4
Tamiya anodized aluminum 4mm flanged lock nut Blue
Tamiya Clamp Type Aluminum Wheel Hub (4mm Thick)
Tamiya TA05 Aluminum Motor Mount
Tamiya TRF Dampers (special blue)
Tamiya TA05 Aluminum Differential Joint Set (w/blades) x 2
Tamiya TA05 Urethane Bumper Black (limited edition)
3Racing Parts
3Racing Carbon Bumper Frame
3Racing Aluminium Front knuckle Hub
3Racing Front Stearing Knuckle
3Racing Aluminium Rear Knuckle
3Racing Aluminium Turn Buckle Links
note: i will includes all orginal parts tat i've changed. box, manual n wat eva spares i can include will be include! all this going for $280 only! sms mi at 82 014 015 =)
Tamiya Parts
3Racing Parts
Brand new 1/10th nitro body shell
As the title suggest,I've got 1 unit brand new shell for sale at $40.Never been run.Taken off the moment I got the kit.It's from the Kyosho Fazer kit.No scratches whatsoever.No pix but it looks exactly like the one in the link.
http://www.kyosho.com/eng/products/r...duct_id=100414
PM if interested.
PM if interested.
Very Good Condition TA05R with typical under chassis scratches with the following new parts and hop-ups for sale,
-New Tamiya 48mm Swing Shafts
-New Tamiya 48mm Light Rear Swing Shaft Blue
-New Tamiya Aramid Drive Belt
-New Tamiya 04 Module GP Spur Gear 105T For TA05
-New Tamiya Carbon Reinforced Bulkhead
-New Tamiya Carbon Reinforced Chassis Stiffeners
-New Tamiya Carbon Reinforced Stabilizer Holders
-New Tamiya Reversible SwingArms
-New Tamiya EvoIV Rear Uprights
-New Tamiya EvoIV 4 Deg C Hub Carriers
-New Tamiya Plastic Lower Bumper Holder
-New Tamiya Tamiya Wheel Axles F/R
-New Tamiya Tamiya 950 Wheel Bearings
Hop-ups
-Brand New Tamiya Direct Spool couplings
-Tamiya F/R Stabilizer (Milky BLUE)
-Tamiya Alum. Differential Joint Set
-Tamiya Carbon Damper Stay (Front)
-Tamiya Carbon Damper Stay (Rear)
-Tamiya Lightweight Alum. Servo Stay
-Tamiya Carbon Centre Plate
-Tamiya Lightweight Center Shaft
-Tamiya Alum Motor Mount
-Brand New Tamiya Wide Pitch Front One-Way Pulley (36T Size)
-Tamiya TB Evolution IV Urethane Bumper
-Tamiya Ball Differential Protective Seal
-3Racing Alum Center One Way Set
-TOPCAD Alloy Motor Guard
Inclusive of,
-Plastic Spares
-High torque servo saver
-Tamiya TA05R stickers
...all for $280
No personal warranty.
No Reservation.
First Come First Deal.
Cash Deal in Singapore Currency Only.
Self-Collect at my place in Bukit Batok at my convenience.
Interested please private message me with your name and contact number,
or email me at [email protected] (Please specify interested items).
Hop-ups
Inclusive of,
-Plastic Spares
...all for $280
No Reservation.
Performance and Durability! Xray T2 '07+spares $450
Don't know why suddenly cannot attach pictures. Anyway, PM / SMS me your email address and I'll email you the pictures.
Price is of course negotiable.
As you may already know, Xray T2 '07 is a high end, high performance and probably the toughest touring car chassis around. Unlike other brands, this car needs no further hop ups. Front diff is Xray's patented MultiDiff that can change from Spool to Front One Way to Locked One Way. Parts availability is very good at BK's track and Hobbylink.
Electronics NOT INCLUDED.
Usual scratches under chassis. Condition on top is as good as it gets.
Spares included, just in case you need them.
- Carbon fiber rear tower
- Carbon fiber front tower
- Hudy Spring Steel Drive Shaft
- Spare lightweight aluminium ball diff
- Other plastic parts also!
New unpainted, uncut, body shell with stickers included.
I'll even let you have my old battered shell.
Used wheels/tires included also. Box and instruction manual included also.
Didn't play much since I got it. Now thinking of other hobbies.
Would like to get around $450 for it. Let me know if you are interested.
SMS me at 96911216 and leave your name.
Stuff for Sale
Team magic G4s nitro car for sale. Newly built, never play with it. Kit come with e ed kit. Also come with stratus bodyshell. Everything sell for $350. Engine & pipe not included. Can view this car at Turf City Atalon R/C shop. Unit #01-37
Falcon .12 size engine with pipe for sale. Both engine & pipe only run-in a few tanks. Very good compression. Selling at $350.00 for both e engine & pipe.Can view this engine at Turf City Atalon R/C shop. Unit #01-37
Take both G4s & falcon .12size engine at $650
Hiro Seiko Alu Steering wheel for Futaba transmitter. Come with adapter for e TX, disk brake & alumin gold screws. Selling as a package for $90.00
Interested Please contact Tony Neo at 97517372. Pls sms or pm me as sometimes not convenient to ans call. Will prefer to meet at Tiong Bahru area. Thanks. (NO RESERVATION, FIRST COME FIRST SERVE)
I got a NIB Hotbodies Cyclone WCE kit for sale. Selling for $730.
Interested pls contact Tony at 97517372. Will prefer to meet at Tiong Bahru area. Thanks
