Hot Bodies D413 1/10 4WD Buggy
Just fitted the 2.0 sway bar from d8.
Only needs bending and cutting and the ends.
Will hopefully try it this weekend☺
Edit: i use the switch sway bar holders with some shortes link i had laying around. Also mounted them the other way in rear so that they dont bind with the upper link
Even with 50k in the centre of mine, when I launched at the start of my final I did a back flip on the spot. Once moving, 50k was fine.
How many of you folks here have upgraded to the +6mm chassis? pretty expensive upgrade with the seperate top decks, especially when compared to the complete kit from schelle although it's 2.5mm and only +4mm....Comments?? Anyone compared the two??
Yo RedBMaster
Don't bother with them they will snap very easy. Just buy a bunch of the stock ones and do not locktight them. There were designed to bend as Torrence has stated on this forum.
Hi, I'm trying to rebuild my diff and when I look at ronnefalk worlds setup, it says slipper. What does it mean? Thanks..
Thanks for the input! I need some loctite as I had one back all the way out during practice. I do go ahead and buy a couple sets of screws tho.
anyone how if the D812/D815 shock stand offs will work on the D413 aluminum shock caps?
I used mugen stand offs on Thursday night and things went real good. i was afraid of not having any slop or play it would cause other items to break or bend i was really ruff on my car and nothing happened. experiment went great Im pretty sure d812 and mugen stand offs very close if not same hope this helps.
