Receiver Pack Problem!!!!!!!!!
I have a duratrx 1600 mah nimh hump pack battery and im using an hpi wall charger that came with a different battery. When i charge the battery it doesnt feel warm at all. Here is a pic of how im connecting the battery to the charger. Am i doing it wrong?
http://i453.photobucket.com/albums/q...jhghgggggg.jpg
Why not just get a peak charger?
Can't see for your thumb, but exactly as stated above - make sure connectors are lined up so the black wires are on same side. Connector has anempty pin, so make sure the pins are lined up across the 2 connectors.
It should at least get warm when its charging. Check voltage, maybe its charged and that charger has a cutoff??
I think your battery is very hungry.....the wall charger is not gonna to cut it...get this
http://www.dynamiterc.com/Products/D...ProdID=DYN4056
u will be fine, least expensive u can get
