Receiver Pack Problem!!!!!!!!!
I have a duratrx 1600 mah nimh hump pack battery and im using an hpi wall charger that came with a different battery. When i charge the battery it doesnt feel warm at all. Here is a pic of how im connecting the battery to the charger. Am i doing it wrong?
http://i453.photobucket.com/albums/q...jhghgggggg.jpg |
Originally Posted by jhipps835
(Post 5848940)
http://i453.photobucket.com/albums/q...jhghgggggg.jpg Why not just get a peak charger?:nod: |
I just got the battery from a friend so the thought of a peak charger hasnt passed my mind. But im not sure what you mean about ground to ground?
What can you see by my pics? Does it look hooked up right> |
Anyone?
black wire to black wire and red wire to red wire
Can't see for your thumb, but exactly as stated above - make sure connectors are lined up so the black wires are on same side. Connector has anempty pin, so make sure the pins are lined up across the 2 connectors.
It should at least get warm when its charging. Check voltage, maybe its charged and that charger has a cutoff?? |
Looks like your thumb is charging just fine:D
If its a used battery it may be crapped out, sometimes they dont hold a charge anymore |
How old is the battery? Also check and see if the wall charger is getting warm. If it's not it is probably a bad charger.
The battery is brand new. And yes the wall charger is getting warm
I think your battery is very hungry.....the wall charger is not gonna to cut it...get this
http://www.dynamiterc.com/Products/D...ProdID=DYN4056 u will be fine, least expensive u can get:D:lol: |
Originally Posted by meon99
(Post 5851482)
Trickle charging will not warm the battery ;)
If it's only charging at, say, 150mAh, that battery will never get warm... Ever. Not sure what that HPI wall unit puts out, but it's probably just a trickle charger... |
Originally Posted by drperry
(Post 5852180)
If it's only charging at, say, 150mAh, that battery will never get warm... Ever. Not sure what that HPI wall unit puts out, but it's probably just a trickle charger... and they take about 16 hrs to charge the pack ;) get a good charger . |
