Yokomo MR-4TC SD
#5252
Originally posted by Randman
I cant find the gas spring rates anywhere, anyone know where they are listed?
Yokomo
Spring Rating [lb/in]
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Rayspeed
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Associated
White 40.00
Yellow 31.91
Purple 30.30
Copper 23.26
Red 23.08
Gold 18.35
Blue 16.53
Silver 13.89
Green 11.43
Tamiya
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 13.24
Yellow Short 12.90
Red 11.86
#5254
That chart still doesn't include the GT4 springs.
You can find a chart somewhere on www.cml-distribution.co.uk
#5255
Just wondering, how many A-arms have you guys broken on your SD?
I've snapped like 8 over 4 months! They are really fragile!
I thought by changing to the graphite arms would make it stronger but snapped on a very light hit.
Anyone else experience this?
#5256
Asimo - I broke 1 arm the first day I ran the car, but no more since then.
Chris Tosolini - I was looking at your setup, would it also work with the Rayspeed shock towers and SS shocks, or are these only for outdoors? What difference does the shock type (SS or SSS) make? Thanks
#5257
That's a hell of a lot stiffer than I'm running with RS sprngs... I have a full set of AE so I think I'm going to have to give that setup a try... Pissed cause my damn printer died though... I can get pretty close with the AE springs as far as rates go...
#5258
I've never broken an arm. I had my second ever breakage this week, decided to go flat out in 19turn into a girder embedded in a wall... smashed the upright (my second) and the C-hub (my first).
Oh, and graphite arms will be more fragile - this is partly because they are stiffer, so they don't flex and absorb the impact. AE recently wrote up an article about common graphite myths.
#5259
I too am using the AE springs. A Purple AE front and a Copper Rear AE would be very close to what Chris had on his setup...also I think that is the combo that many of the Tc3 Racers are using on carpet.
Looks like I will have to get me some Jaco foams...gotta think if Josh Cyrul and Chris both run that combo...would be more then good enough for me...lol
Jeff
Jeff
#5260
#5261
I think I'm going to try the Yellow/copper tomorrow, if I need more steering I'll drop to the purple...
#5262
#5263
If I wanted to follow that setup sheet... I understand the front anti dive, which spacers are for the front? And... The suspension mount height spacer? Which are they refering to??? Never played with it before,...
#5264
#5265
