Mugen MBX5R
#1441
New engines are very tight, you wanna heat the engine before you start it up with a heat gun or hair dryer, and/or loosen the plug before starting, and/or put in another head shim. Heating the engine before you start it is the best way, less strain on the conrod.
#1442
sounds like its stuck at TDC no amount of cranking will unstick it, you will have to manually force it back by levering the flywheel with a screwdriver brutal i know but thats the way, once its free make sure the piston is near the BDC then heat up the engine with a hairdrier so its nice and hot then try again, never leave the motor stuck at TDC always bring it back down the liner
#1443
Most new engines these days have a crazy amount of 'pinch' when new. Heat that engine up with a heat gun or a hair dryer before starting. That'll make the 'pinch' much easier for your starter box to spin through. It'll be a lot easier on the connecting rod too. When you preheat the engine the sleeve expands to near running dimentions.
Heat the head and the upper portion of the crankcase until you get a 200 degree reading at the glow plug. You can also rotate the flywheel backwards by hand until it stops. This will give your starter box a 'running start' when spinning the new engine over for the first time.
When heating the engine with a heat gun be carefull not to melt plastic parts on the car---epecialy the body!!!
Edit:
D'Oh!!! Why didn't I see that two other guys had already said the same thing????
#1444
Registered User
Use a hair dryer dont have to worry about melting parts, the ole dryer will get it hot enough!!!
#1445
Will the 38T crown gear work with the 13T bevel gear for the front diff?
I've read somewhre on this thread that someone preffered it than the 11T bevel because it meshed better.
Also will it work, performance wise?
I know that some use the 38/11 on the rear but the ratio is closer to 43/13 than the 38/13.
#1446
Sorry, I'm being a little lazy and don't want to read through 50 pages
Can I get some information on the BCE chassis, does it really help the 5R that much, if so how? I'm only club racing and just bought a 5R, does anyone have a chassis for sale by chance?
Thank you!
Thank you!
#1447
Thanks guys got her up and running. What is everyone doing with the exposed ball joints around the wheels, are boots available?
#1448
Life in the old dog yet 3rd place at the worlds running with the new MBX6 shocks and towers
#1449
Im pretty sure he was running a 6 i just looked at the pics and the tank is diffirent as well as the radio tray
#1450
#1451
Thank you!
Thank you!
I personally felt the BCE chassis gave the car more steering and i have heard that it does not wear as quickly in the rear like the stock 5R chassis.
#1452
#1453
MBX5/5R Prospec Parts
Hey guys,
Cleaning out the race room, and I have a batch of MBX5/5R Propsec parts listed on Ebay. Do a search under Mugen.
Cheers,
Cheers,
#1454
That car is without a doubt a X6!!! My frien was driving his today and he said the best difference is the acceleration. There will be a Pro spec kit with ti screws and rear alluminum hubs. Box says US version with carbon towers. I was curious as to why I seen some kits with cnc towers. Not to many options to buy here for this car. For $850 car I guarantee the makers of Kyosho will come out with option parts. It never fails!!! Dont know what parts because it also looks pretty complete. Next year will make for some good racing for sure with all the cars out. Funny after all these years Mugen had changed their air filter to a 2 stage. They have been using the same filter since '93(Athlete). Always worked though. Only part I can see carried over from the X5 is the steering slider.
