Hot Bodies Cyclone
Me too!
also the cyclone TC has a plastic belt tensioner, servo mounts, spring pirches, shock bushings, etc vs the WCE has all alloy.
you do realize that most of the "pros" run very little alloy on their cars? aside, from the cvds and heat sink parts?? Can this car be a "pro level" car - as in "this is what the pros run, no need for anything else"??
you guys that want a 100% alloy chassis really baffle me - if you want that much allow, run 8th scale or 5th scale....you'll get all the alloy you'd ever want there
you do realize that all the parts you (in particular) mention are more for show than go, right??
And yes, I do see all the alu parts on the pro HB's drivers.....
I have a Cyclone Black. I can just get the chassis plates and diffs or do I need the bulk heads too?
if your Cyclone is black , i'm think you change new kit !
because the first lot cyclone all alum. had used remade alum. ,
so some soft !!
You wont need the bulkheads.Get the diff and maybe the multi diff for the front.I doubt anything else will be needed
This new TC kit not have 3mm CERAMIC Diff Ball !!
Current pic with new brushless setup. LRP/Team Orion. I was going to get a Speed Passion 10.5, but everytime I go to order it everyone is out.
