http://losiracing.blogspot.ca/2012/0...e-pistons.html
ok, sorry newbie here so have to clarify things. The AE piston set comes with a 1.6mm 2hole already but the 22 #55 mod requires the glueing of 2 holes then drilling the remaining 2 holes with a 1.6mm drill. Wont that make the hole the same size as the AE? or is the actual piston size too big to fit in the shock body?
Tech Prophet
My bad, thank you.
whats a good motor for the scte in the novak brand?
Tech Prophet
Plus at the time my LHS carried more 8ight stuff and NOW the electric is booming here and the nitro stuff is blah and hardly sells and doesnt carry any nitro stuff really and there is alot more support for the SCTE which is awesome so maybe 1 day i will try to get some stock shocks again...
I would go with the 550 balistic line. 4.5T
http://v2.teamnovak.com/products/ind...d88541dd410b2e
Not that im arguing with you but this truck is not 6lbs...RTR with everything in the truck and i even have a few mods im still running high 6lb to 7lbs weight range. But ive had this truck for awhile and there really wasnt alot of stuff suspension(shock stuff) available at the time and there was a TON of 8ight stuff. I have had good luck with the 8ight shocks BUT you will spend alittle more for these parts and to make them work and would really like to go back to the stock shocks and see how it handles since its been so long from running the stock shocks but i would want the HA bodies and all the snazzy stuff like i have on my 8ight shocks on this truck now .
Tech Prophet
I agree RTR out of the box it is close to 6.7lbs. My 2.0 and the 1.0 it replaces are hitting the track closer to 6.2 lbs. (really did no do anything special to the 2.0) If you guys are getting the 8ight shocks to work more power to you. I love the stock SCTE shock and have have extermely good luck with them. Not saying the 8ight ones are bad as they are great as well just don't see the need for the extra cost.
