Team Losi JRXS Type-R
#2851
Originally Posted by David Alberico
syndr0me - using the one-way for outdoor?
#2855
thats terrible cause no parts and car first losi partshouse has some parts instock check em out...i order my xxx-s parts from them all the time...
http://www.losipartshouse.com
#2856
Originally Posted by LosiPartsHouse
Search Results
Sorry, no matches were found containing LOSA1217.
#2857
Guys, just order the old front arms......they work and are actually stronger....
I am sorry, but the new material of the arm kinda sucks.....Garrett broke like 4 of them since getting the kit.....he was about to call it a weekend, but I had some old arms.....put them on his car and he didn't break a front arm the rest of the weekend....
Later EddieO
Later EddieO
#2859
dont know the part number off the top of my head but its the old bk arm. they are shorter so you have to put the arm in the wide setting, i didnt have the bk arms so i had to use the older ones, changed my geometry quite a bit, had to go to a way stiffer spring, got the car really good though....parma bumper helped out alot....if you get the bk arms i think it is the same shock position.
#2861
Originally Posted by syndr0me
What's the part numbers F/R of the graphite arms that are a direct replacement on the R?
Mike Slaughter
#2862
Originally Posted by Livingston
Ran the Type R for the first time today at Aldershot SLCC on RP30
contol tires.
Qualified pole in B final, finsihed second in first final, won the second.
Tried the car in practice on Saturday with high role centre blocks and
found car too twichy.
Ran the car today with low centres but with the older car large spacers
under blocks, car much better. 25Wt spring on front and 20Wt on rear.
Will try running role even lower at WLRC next Monday.
Car has loads of grip and steering.
Chris
contol tires.
Chris
I to will be at Wet London if it don't rain that is, as club members will be able to play with the beginers, (that don't sound right but wtf ) but in different heats obviously (hope to have the car Thurs/Fri, so should be able to give it a run) please come over and introduce yourself
Cheers Malc
Genrally pit in front of the Rostrum (not on th track tho ) you'll hear me
#2864
Originally Posted by TheCoolCanFanMan
So Chris, have your lap times come down at all with the new car?
Cheers Malc
Cheers Malc
