Serpent 960....
#1846
Originally Posted by Winner's Circle
Jeff,
The 902110 is a 950 tank which is slightly different thatn a 960 tank. The difference is in the area at the back right where the carburetor slide is. The 960 has a deeper recess to clear the carb slide.
The Vector tank is PN# 1430 and it is a completely different shape as far as the length and width and will not fit into the area provided on the radio tray.
I have both of these tanks in stock in case you can't fix what you have.
Happy New Year!
Happy New Year!
I bought it on my lhs
anyway
I'm mounting a Mega ZX21 DSII on the Vector Chassis and I've got a problem. The bottom of the crankcase is touching the chassis.. The manual says it cannot touch but don't explain how to solve it.
What should I do?
#1847
Originally Posted by jeff1
anyway
What should I do?
anyway
What should I do?
#1848
anyway
What should I do?
anyway
What should I do?
#1849
anyway
What should I do?
anyway
What should I do?
#1850
I have some Kyosho shims 3x5mm 0.1 0.2 and 0.3mm of thickness. hmm.. do you mean place them between the engine "support" and engine mount?
If that don't work I will try to grind it a little, I will try that for last.. I'm hesitating for this alternative because I think it will take rigidity of the chassis and make it weak, not sure
Thanks guys!!
I'm waiting your test Roniel
see you
Thanks guys!!
see you
#1851
Jeff:
The monoblock does not work but i found a set of the spacers that Lee mentioned that Serpent made for that,pm me with your address and ill mail them to you...
#1852
This same problem rised whit the EVO5 engine, which also has a bigger crankcase, with the EVO5 a new set of engine blocks where introduced, so maybe you should mount the ZX on these.....
I think you need a set off these:
http://www.mytsn.com/product/902340/
@Roniel R, the monoblock does not fit?....
#1853
No the monoblock does not work its about 5MM short...
#1854
#1855
Its also better not to use the monoblock! A monoblock will restrict the max rpms due to vibrations....
#1856
Originally Posted by Roniel_R
Explain to me how the monoblock creates more vibration than the regular two piece motor mounts????
This is a tested statement
#1857
WOW you learn something new every day....
#1858
Developments
There are a lot of things to learn and therefore a lot of new developments.
Here is one of them http://www.serpent.com/product/903220
Smaller bearings have a smaller contact footprint and less rotation-mass. This results in a smoother and lighter rotation. On the other side it will also reduce about 30 grams of overall weight.
Stay tuned, other developments are on track....
#1859
Originally Posted by PMSorber
The two piece mounts are standallone, so vibrations will not directly be transfered to the other mount. The monoblock will directly transfer vibrations from one side to the other... these collisions in vibrations will restrict the performance of the engine.
But Pieter, you might have a point there.....
But a monoblock also makes the area around the engine a lot stiffer, which then eliminates as much as possible any stress on the crankcase.....
So in the end......
#1860
and it is not because your JP engines don't fit in a monoblock?... (don't know, just wondering)....
So in the end......
So in the end......
So in the end martin ... we broke the monoblock down to two pieces and gained about 1,5k-rpm. Stiffer on this block is BAD!
