Old 01-04-2007, 03:45 PM   #1846
jeff1's Avatar
Originally Posted by Winner's Circle
Jeff,
The 902110 is a 950 tank which is slightly different thatn a 960 tank. The difference is in the area at the back right where the carburetor slide is. The 960 has a deeper recess to clear the carb slide.
The Vector tank is PN# 1430 and it is a completely different shape as far as the length and width and will not fit into the area provided on the radio tray.
I have both of these tanks in stock in case you can't fix what you have.
Happy New Year!
I bought it on my lhs
anyway
I'm mounting a Mega ZX21 DSII on the Vector Chassis and I've got a problem. The bottom of the crankcase is touching the chassis.. The manual says it cannot touch but don't explain how to solve it.
What should I do?
jeff1 is offline   Reply With Quote
Old 01-04-2007, 04:24 PM   #1847
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
Originally Posted by jeff1
anyway
What should I do?
hm, maybe you can grind on the chassis 1-2 mm?
Orfeous is offline   Reply With Quote
Old 01-04-2007, 04:24 PM   #1848
Winner's Circle's Avatar
anyway
What should I do?
You can dremel the chassis under the centerline of the engine to make room. Don't take out much material but just enough to get it to clear. Serpent used to offer some shims that sat on top of the motor mount in order to space the engine up slightly but I have not seen any of them in years.
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 01-04-2007, 06:11 PM   #1849
Trader Rating: 4 (83%+)
anyway
What should I do?
You can also try the engine monoblock it may clear and you dont have to grind the chassis,i have a vector and ill try the monoblock later today and ill let you know...
Roniel_R is offline   Reply With Quote
Old 01-04-2007, 08:44 PM   #1850
jeff1's Avatar
I have some Kyosho shims 3x5mm 0.1 0.2 and 0.3mm of thickness. hmm.. do you mean place them between the engine "support" and engine mount?
If that don't work I will try to grind it a little, I will try that for last.. I'm hesitating for this alternative because I think it will take rigidity of the chassis and make it weak, not sure
Thanks guys!!
I'm waiting your test Roniel
see you
Old 01-04-2007, 10:04 PM   #1851
Jeff:
The monoblock does not work but i found a set of the spacers that Lee mentioned that Serpent made for that,pm me with your address and ill mail them to you...
Old 01-05-2007, 01:00 AM   #1852
M7H
M7H's Avatar
This same problem rised whit the EVO5 engine, which also has a bigger crankcase, with the EVO5 a new set of engine blocks where introduced, so maybe you should mount the ZX on these.....
I think you need a set off these:
http://www.mytsn.com/product/902340/
@Roniel R, the monoblock does not fit?....
Serpent
M7H is offline   Reply With Quote
Old 01-05-2007, 06:11 AM   #1853
No the monoblock does not work its about 5MM short...
Old 01-05-2007, 06:22 AM   #1854
Send a message via MSN to PMSorber
Its also better not to use the monoblock! A monoblock will restrict the max rpms due to vibrations....
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 01-05-2007, 06:34 AM   #1855
Explain to me how the monoblock creates more vibration than the regular two piece motor mounts????
Old 01-05-2007, 06:57 AM   #1856
The two piece mounts are standallone, so vibrations will not directly be transfered to the other mount. The monoblock will directly transfer vibrations from one side to the other... these collisions in vibrations will restrict the performance of the engine.
This is a tested statement
@ConSult Trading
Old 01-05-2007, 07:11 AM   #1857
WOW you learn something new every day....
Old 01-05-2007, 07:44 AM   #1858
Default Developments
There are a lot of things to learn and therefore a lot of new developments.
Here is one of them http://www.serpent.com/product/903220
Smaller bearings have a smaller contact footprint and less rotation-mass. This results in a smoother and lighter rotation. On the other side it will also reduce about 30 grams of overall weight.
Stay tuned, other developments are on track....
@ConSult Trading
Old 01-05-2007, 07:46 AM   #1859
M7H
M7H's Avatar
and it is not because your JP engines don't fit in a monoblock?... (don't know, just wondering)....
But Pieter, you might have a point there.....
But a monoblock also makes the area around the engine a lot stiffer, which then eliminates as much as possible any stress on the crankcase.....
So in the end......
Serpent
Old 01-05-2007, 07:55 AM   #1860
So in the end......
They fit on the monoblock without any problems, there is a Novarossi monoblock you know ...
So in the end martin ... we broke the monoblock down to two pieces and gained about 1,5k-rpm. Stiffer on this block is BAD!
@ConSult Trading
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
