TLR TEN-SCTE 2.0 Kit Thread >
Like Tree10Likes
Old 02-03-2014, 12:43 AM
  #6046
MRANTITRAXXAS's Avatar
Originally Posted by Dracer
I have the 2.0 with a tekin 4300 and RX8 gen2 speed controller. This setup was bought new 2 weeks ago. I am running a high voltage servo. I have a glitch buster. My problem is this thing will stop running I will still have servo but no throttle. My motor and speed controller is running cool. Motor 135 deg. speed controller less than a 100 deg. I am running a deans plug to connect battery. Battery is a SMC 6500. Sometimes this thing will only run 5 minuets and sometimes it will run for a 8 min race. Battery is sometimes still at 65% when it does this. Please help
Ya might try re-binding your radio and resetting endpoints.
MRANTITRAXXAS is offline
Old 02-03-2014, 05:13 AM
  #6047
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by BSR31
use SNR carbon tower shock if u stay in US... the tower shock has 2 hole.., one standard hole for standard 12mm shock, and other hole is 9mm higher hole than standard for 16mm TLR 3.0 shock... it seat perfectly...
Those towers are made for the 2.0 shocks. 3.0 are longer.
rcgod is offline
Old 02-03-2014, 06:05 AM
  #6048
banana rt's Avatar
Thx. Mr.Rudy. see u on another run
banana rt is offline
Old 02-03-2014, 04:03 PM
  #6049
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
Originally Posted by rcgod
http://www.casper-rc.com/images/TEN_..._13_reduce.pdf
What is THE setup that everyone is using as a baseline? Also, anything not included in the kit that I should order? Different springs, pistons, necessary upgrades, etc?
Does the kit include everything to run this setup or are there any springs, pistons, mods, etc needed?
CaptainHowdyt13 is offline
Old 02-03-2014, 04:07 PM
  #6050
P.S. I'm looking to buy a clean, racer maintained roller if anyone has one
Old 02-03-2014, 04:21 PM
  #6051
rcgod's Avatar
Not sure if the kit comes with extra pistons you'll need 4 of the #3s. You'll also need the option springs front and rear.
rcgod is offline
Old 02-03-2014, 04:25 PM
  #6052
Which springs? I'm not able to open that setup sheet on my phone.
Part #s for the pistons/springs?
Old 02-03-2014, 05:24 PM
  #6053
DoogieLee's Avatar
Trader Rating: 42 (100%+)
http://www.losipartshouse.com/servle...ies/Categories
The springs and pistons are on this page.
I love Losi parts house, those guys are on the ball with shipping and they have great prices.
DoogieLee is offline
Old 02-03-2014, 05:32 PM
  #6054
So just get the whole F/R sets and the complete piston set. Gotcha
Old 02-03-2014, 05:41 PM
  #6055
DoogieLee's Avatar
Yeah, I didnt see where the individual springs that we need are listed.
It could be and im over looking it...
Old 02-03-2014, 08:18 PM
  #6056
BSR31's Avatar
this tower shock have 2 hole as i mention it before...
lower hole for original shock (12mm) and higher hole wich is 9mm taller than original is for big bore 16mm shock. and seat perfectly...
you may cek to SNR graphite...
thx
BSR31 is offline
Old 02-03-2014, 10:51 PM
  #6057
BmainStar's Avatar
Originally Posted by BSCFlash
It takes a VERY hard smack, but I have seen it more than a dozen times, under the same circumstances. There was even a thread about this several months ago, and someone explained why it happened (not sure what site, though). Maybe Randy Pike can chime in for an explanation. In fact, we saw this four times yesterday alone! (It was a very tricky jump we had to adapt to.) All of our ESCs are relatively new, or new, so something is certainly going on!
..I have seen this happen .just did not think it to be common.My guess( only) would be that a few prior hits would loosen something up and a few more hits would seal the deal. Here we have very groomed and near perfect 10/th scale tracks.no 1/8 track jumps or such.I have 3 rx8 on the bench that (should go back to tekin) so I know of the faults.
There has to be a benchmark with how much of a hit it should be able to take and keep on ticking.Perhaps the jump you speak of is over that very benchmark?.
BmainStar is offline
Old 02-03-2014, 10:54 PM
  #6058
BmainStar's Avatar
The springs come in sets at 16 bucks per!!!!!Am running the black set front and orange rear with 3 and 4 pistons from the 1.0 set up with 27/5 rear and 32.5 front!!!!!!!
Old 02-03-2014, 11:17 PM
  #6059
DoogieLee's Avatar
I was wondering if the old "go to" spring setup from the 1.0 would work on this...
Hows the class at Pegasus these days?
I'm going to be heading out there in about a month, its been 2 years since I was there last and I had a great time.
Old 02-03-2014, 11:36 PM
  #6060
AlanHall's Avatar
Trader Rating: 43 (100%+)
ill have one with a mip conversion on it shortly.
AlanHall is offline
