TLR TEN-SCTE 2.0 Kit Thread
#5296
No drag brake. It dos spin out more to the right now that i think about it. but i do have a lot of right hand turns on my track. I didn't notice any bearings that where hanging. but i could inspect them better. My spur gear is a little loud. could this be causing enough drag to throw the Diff's off?
#5297
BTW... anyone want a free torque rod for rear? Just pay shipping PN# LOSB2426
#5298
Not unless the pinion gear is tight against the spur. As long as the mesh is set right there shouldn't be a problem. I would go through the whole truck and check all the bearings. Make sure they are all smooth and quiet when spinning. I had a rear diff bearing go out in my 2.0 after 3 race days so anything is possible.
#5299
The mesh is set right. I guess ill have to just break the whole truck down and check all the bearings in hubs and diffs.. The only reason i didn't do it yet was because the truck had very little run time on it and everything looked good. Thanks for your input. Ill post back if i find anything out of the ordinary. thanks
#5300
This is for a SCTE 1.0 with the original BCE chassis. So it sounds like I can run this rod on the rear (LOSB2426), will the 231010 part number work on the front of a 1.0 or should I just run the rod that I have in the rear and go with something else in front?
#5301
I was thinking about getting the MIP tweak board and trying it out. Has anyone tried it or do I need to keep measuring shocks, checking ride height, and leave it be. Does anyone use a tweak board on off road vehicles?
#5302
Tweak is more of a concern for double decker chassis braces you find on touring cars with really a rigid chassis. You could actually FEEL the chassis 'untweaking' when you loosened the screws holding the top brace on those things lol.
#5303
That makes sense. I also understand that checking tweak is a good way to see if the chassis is bent or warped. Just wasnt sure if it was worth doing on a off road vehicle.
#5304
So far the only thing i see is the rear diff is full of metal shavings.. Still feels smooth so i might be able to just add new fluid and be good. Both of the otter bearings on the diff feel a little rough also.. im replacing them now hopefully this will take care of the problem...
#5305
#5308
17mm hex adaptors for Losi scte
Mitch from M2C RACING here.
I made this kit so you guys could run the buggy tires in the yard or where ever.
my question is that I need to know if this kit is what you guys need.
I have hear of guys using the larger axles from the 10-t .
If you want something else that will make it better. let me know as these have been
selling quite well all of a sudden.
#5309
#5310
I bought those adaptors two days ago. Just waiting for them to arrive.
