Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 12-03-2007, 01:25 PM
  #4741
fatbear's Avatar
Originally Posted by Verndog
You can buy the nut sepperatly, I have the part number at home, comes in a pack of 4...I'll post later today. However to have to buy the diff nut plastic retainer from the stock outdrive kit for $5.00 to get the plastic those. Another option is to try to press the old nut out of your retainer and the new nut in.
Thanks Verndog,
I look forward to getting the part number for the diff nuts.
fatbear is offline
Old 12-03-2007, 04:27 PM
  #4742
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by fatbear
Thanks Verndog,
No problem. I've confirmed these fit, I rebuilt a diff using them.
ASC3904 2-56 Locknut
As posted the plastic nut retainer is only available in the outdrive kit.
ASC31167 Plastic Diff Outdrives
Verndog is offline
Old 12-03-2007, 05:48 PM
  #4743
Brandon Melton's Avatar
Originally Posted by naggalowmo
Actually I have tried using less castor by going from 6* to 4* and the change was too drastic. I was having WAY too much push mid corner and trying to exit the corner. Would you have any other suggestions?
I'm running on a VERY tight high traction carpet track and most of the turns are U turns if that matters any.
Well, depending on what borders your track uses, you could try a spool when using the 4*. I have tested a spool on carpet and it was just as fast on the clock, drove better, but front end collisions will usually break the blade on tight carpet tracks unless you have flappers or something like that. The spool will not turn in as good but steer very well coming off the corner. If you can get away with running a spool, you could even try 2* caster.
Brandon Melton is offline
Old 12-03-2007, 06:39 PM
  #4744
Tim W.'s Avatar
I raced this car for the first time saturday all I can say is WOW. It was hooked up out of the box. Its loads better then my jrxs ever was. Great job AE on a amazing car. Btw I got 2nd in expert mod with it the first time out
Tim W. is offline
Old 12-03-2007, 06:42 PM
  #4745
RCpurplecow's Avatar
should i run 4 degree or 6 degree caster blocks for asphalt? i run 6 degree on foam but wasn't sure about asphalt
RCpurplecow is offline
Old 12-03-2007, 07:13 PM
  #4746
Trader Rating: 74 (100%+)
I would run 4deg for asphalt
steve eaves is offline
Old 12-03-2007, 10:43 PM
  #4747
K_Spec_RC's Avatar
fatbear, I used the Stealth T-Nut/Thrust bolt kit to rebuild my diff. Works a treat too! I checked the length of thrust bolt against the TC5 and it is exactly the same length. It seemed to me that the T-Nut was a tiny bit smaller width wise. So just be sure to use the bigger of the 2 t-nuts and you will be just fine.
here is the link for the part, hope this helps!
http://www3.towerhobbies.com/cgi-bin...?&I=LX2869&P=M
K_Spec_RC is offline
Old 12-03-2007, 11:15 PM
  #4748
I think I found the solution to my problem. I put too many shims in the back arm mounts. I was using 1*+2* instead of 1*+1.5* Hard to tell the difference in thickness I also added a little toe and Im getting enough steering now. Thanks everyone for your input.
Hey Brandon I"ll try it out and see how it goes. Thanks for the help!
naggalowmo is offline
Old 12-04-2007, 04:11 PM
  #4749
Trader Rating: 14 (100%+)
What happened to P-Dub bumpers? Anyone know where I can get some for the TC5?
thunderbt3 is offline
Old 12-05-2007, 03:10 AM
  #4750
raceguy13's Avatar
I run my tc5 on carpet in the stock rubber class. My local track is low traction, but I can't seem to loosen my car up enough. When I have went to high grip tracks it just traction rolls. I run the stock chassis and the best it has worked for me was with copper and purple springs. Everyone at my track tells me I'm too stiff. If I soften it up it just seems to have to much bite. Any ideas?
raceguy13 is offline
Old 12-05-2007, 03:19 AM
  #4751
Trader Rating: 90 (100%+)
I would agree that you are definitely way to stiff. Sounds like you do not have any chassis roll and the car is just flipping over instead of letting the suspension work. Try softer springs and more uptravel. That should get you going in the right direction and you can start tuning from there.
RBLove is offline
Old 12-05-2007, 03:22 AM
  #4752
Registered User
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Raceguy
Post your setup. You could try some of the setups on the AE site. Try the Juho L. rubber tire setup as a starting point.
Dasupacat1 is offline
Old 12-05-2007, 04:23 AM
  #4753
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
can someone tell me if the ball studs on this car have 3mm threads if so do you use a 2mm wrench to tighten them
also what are the sizes that come in the kit (part numbers)
thanks Dave
Dave Bowser is offline
Old 12-05-2007, 12:01 PM
  #4754
Maybell's Avatar
thanks Dave
whatup DB!
yes, the ballstuds have a 3mm thread, and a 2mm hex drives them...
Maybell is offline
Old 12-05-2007, 12:13 PM
  #4755
not much how bout with you..................thanks for the info
