Team Associated TC5
#3991
I ordered the TC-5 Layshaft and belt from TIR a 2 weeks ago today.. sent paypal to the address they sent... still no layshaft or belt... I have sent emails and no replies... Anyone have any better luck??
Chad
Chad
#3992
Guys ...
Im still deciding about which electric touring to get between :
- TC5
- Serpent S400
- Team Magic E4
This will be for 19T class with 10.5 brushless system and normal NiMH cells pack. I would like to know wich pros and cons you think the TC5 have, and which extra parts i have to order on the first time in order to be fully competitive ...
thanks,
Pat
- TC5
- Serpent S400
- Team Magic E4
thanks,
Pat
Extra parts, this goes the same for any car. You should purchase extras of anything that hangs off the main chassis. This means everything from steering blocks, front and rear hubs and arms, hing pins, bearings, spacers, shims/spacers, and ball studs.
To get the best for the money, I purchased 2x complete kits to start with. This way you get at least one extra of everything, and then as you use these parts, you start buying extra's from there.
#3994
[QUOTE=kn7671;3682851]... you must have a 2mm ball hex screw driver. ...QUOTE]
Like the one that comes in the kit?
E
E
#3996
I really like the Craig Drescher setup from Snowbirds 2007 for Carpet Foam. Here is a direct link to the PDF from Associated's website for the setup. The car is easy to drive, not twitchy, and has good rear traction.
http://www.teamassociated.com/racerh...wbird_2007.pdf
Corey
#3998
kraig i am waiting for your setup ... i have tools and car in hand ready for surgery
#3999
I recieved my associated spool kit today and i was wondering if it includes the screws that connect it together? because i didnt recieve it. Also if they are not included what are the right screw to use on them?
#4000
Are the TC5 spools in stock now???
#4001
Hi
I have tried the Top racing spool with very good result.
Besides, I prefer AE redesign a new low friction front & rear belt for stock racing, metal spur gear hub & diff. outdrive etc. TC5 has big space to rise the potential, high power racing as 3.5t BL especially.
#4002
#4005
recommendation for AE only
