Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 08-06-2015, 09:47 AM
  #1171
joehundy's Avatar
Trader Rating: 15 (94%+)
This will be a part together type mod for sure ...but you can get all the parts needed for this on Amain.com
joehundy is offline
Old 08-06-2015, 04:31 PM
  #1172
Woulvesbaine's Avatar
Trader Rating: 12 (100%+)
Yoke should really look at this and see if they can make it easy/accessible as I know drivers who are working with this car on clay and dirt and want to get it to generate more rear grip.
Woulvesbaine is offline
Old 08-06-2015, 06:06 PM
  #1173
STLNLST's Avatar
Trader Rating: 32 (100%+)
It won't matter what Yok does if there's only one place to get parts in the US and they are constantly BO
STLNLST is offline
Old 08-06-2015, 07:06 PM
  #1174
8ight-e's Avatar
Trader Rating: 58 (100%+)
What is needed for the pit box?
8ight-e is offline
Old 08-06-2015, 08:27 PM
  #1175
Jim Hughes's Avatar
anyone have a parts list yet? had to buy the wrong stuff stuck with a bunch of crap
Jim Hughes is offline
Old 08-07-2015, 07:17 AM
  #1176
Supertruck1's Avatar
anybody have YZ2's in stock or used for sale ? amain has been out for a while, and absolute hobbyz is now out
Supertruck1 is offline
Old 08-07-2015, 07:41 AM
  #1177
Motorman007's Avatar
Trader Rating: 89 (100%+)
Absolute Hobbyz
http://www.ebay.com/itm/Yokomo-YZ-2-...item541b6a4bf7
Motorman007 is offline
Old 08-07-2015, 08:01 AM
  #1178
Good Luck finding the battery brace. Thats a custom one on lees buggy.
mhuse6969 is offline
Old 08-07-2015, 08:05 AM
  #1179
Originally Posted by Motorman007
thanks for the link..... but ill wait for amain before i pay over retail...on ebay lol
Old 08-07-2015, 08:52 AM
  #1180
mes
Only the cf strap seems to be custom, the aluminum part is the B-Max2 one. I wish I had not sold my B-Max last year, I would have had all those parts in my box.
mes is offline
Old 08-07-2015, 09:20 AM
  #1181
WillS's Avatar
Battery brace is already in the works... depending on vendors time frame expect it fairly soon.
WillS is offline
Old 08-07-2015, 09:22 AM
  #1182
This brace?
http://www.rccarshop.co.uk/index.php...ry-holder.html
Old 08-07-2015, 09:32 AM
  #1183
Jim Hughes's Avatar
my good friend works for absolute hobbies he pulled the one off ebay and put on site also you can use their cuopon codes at http://www.absolutehobbyz.com/Monthl...-_ep_43-1.html and save a little more
Old 08-07-2015, 09:37 AM
  #1184
Very Nice of you.
I got my Yok this week and some extra good stuff. Just waiting for the shock shafts to come in.
Old 08-07-2015, 09:46 AM
  #1185
Jim Hughes's Avatar
Very Nice of you.
where did you order that stuff from
