Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 05-11-2002, 12:43 PM
  #2041
I have yet to run Sorex's. Do they have a compound like the TakeOffs? Also has anybody tried the new Orion tires?
Phatz
Phatz is offline
Old 05-11-2002, 12:44 PM
  #2042
Jonski,
Those cells do fit tight in the Mission. Did you sand the edges of the battery slots? That helps the cells to fit.
Phatz
Phatz is offline
Old 05-11-2002, 02:10 PM
  #2043
Regional Moderator
Darkseid's Avatar
jonski: I couldn't fit my 3000HV's in my Mission at all at first. The matched Integy cells came with an extra layer of shrink wrap on them. It just made it impossible to fit them in the car. I had to break down and remove the extra layer. I also added one thin metal washer under each post. After doing those things, the cells dropped right in with a perfect fit and perfect tension from the battery strap for all my Sanyo cells 2000-3000HV. Try doing these things before you start sanding on the chassis. It should work for you.
Darkseid is offline
Old 05-11-2002, 08:42 PM
  #2044
Damon_KJ7E's Avatar
With no shrink wrap the Sanyo 3000HV are a perfect fit. I found I cracked the rear of the front right upper suspension arm. The camber turnbuckle is backed out a good way to give me -1/2 deg of camber and I don’t think it left enough in the arm to provide much strength (that or I hit the board hard?). Need to order spars. Is this a common problem? Does anyone use a longer turnbuckle to help resolve this?
Damon_KJ7E is offline
Old 05-11-2002, 11:12 PM
  #2045
Default Arms and cells
What I was saying is to do the same thing as pan cars. To sand or file the edges so the cells don't short out against the chassis. Not to much though those chassis get expensive 8). The washer works out great also I use it in my Cat 3000. Shcumacher has longer Titainium turnbuckles to help with that problem. Have your LHS call or call Adrian or Paul and ask for them.
Phatz
Phatz is offline
Old 05-12-2002, 06:12 AM
  #2046
Cole Trickle's Avatar
Default Springs front versus rear
Since the Mission comes with 4 equal springs, I was wondering if it's a good rule of thumb to use the same springs front and rear?
How about the standard inserts, they seems very soft? I think HPI hard would be better for carpet?
Cole Trickle is offline
Old 05-12-2002, 06:31 AM
  #2047
Cole,
It really depends on the setup of the car and how it feels for you. I currently run RED springs all around which is the setup I use for carpet. As for insers ask the fast guys at your track what they are running. Echo makes a red insert which teamed up with some Pit tires makes a great combination. That is what we were running at the Turkey Shoot.
Phatz
Phatz is offline
Old 05-12-2002, 07:05 AM
  #2048
Granted ! But I'm more looking for some starting points and rule of thumbs, not the excat truth (which dont exist!).
On the HPI cars I'm used to, they usually drive better with a little harder springs up front, than in the rear. I've tried other combinations, but always goes back. Most HPI drivers do like this (at least on first and second generation cars).
Old 05-12-2002, 08:06 AM
  #2049
Racer X's Avatar
Damon: If you are using the inline hole on the hub (which you probably be using if you are not), it its possible to break the arm where the turnbuckle enters the arm (the arm cracks an lets the turnbuckle anle btowards the back of the car increasing the camber on that side of the car). The solution is to thread the turnbuckle further into the arm (and further out of the ball grippa) so more of the threads are in the arm. This will take care of the problem. At the same time, you should probably run closer to 1 to 1.5d camber in order to get flat tire wear. Hope that helps...
Racer X is offline
Old 05-12-2002, 08:11 AM
  #2050
Racer X's Avatar
Cole: Run whatever springs you need to run for optimum handling. If you prefer or need to run a stiffer spring in the front, then don't worry about what spring it is, use it. Currently I'm working on a setup with a diff (Reedy Race has a no one-way rule) and am running red in the back and blue in the front. My normal setup, however, is red all the way around. The only thing I try to avoid is running a spring thats is 10 pounds or more than the other, but don't take that as a rule either. Try everything and see what works for you at your track. Good luck...
Racer X is offline
Old 05-12-2002, 09:38 AM
  #2051
Racer X
With the Blues in the front the turn in must be awsome. What weight oil are you running in the shocks? And are you running the new top plate?
Phatz
Phatz is offline
Old 05-12-2002, 12:35 PM
  #2052
RC Raptor's Avatar
They call that A perfect fit!
RC Raptor is offline
Old 05-12-2002, 01:30 PM
  #2053
Trader Rating: 380 (99%+)
My 3000HV's are Integy cells. Looks like I will be taking them apart. Thanks for the information.
jonski is offline
Old 05-12-2002, 10:28 PM
  #2054
Damon_KJ7E's Avatar
Racer X: Other than using the inline hole on the plastic hubs I am running the Aluminum parts. But yes, the arm broke exactly as you described. I will try offsetting the turnbuckle to allow more insertion in the arm. Thanks
Old 05-13-2002, 07:40 AM
  #2055
Regional Moderator
Darkseid's Avatar
Jonski: no problem. You'll be amazed at the fit once you remove the extra layer. Just make sure you don't cut the factory shrink wrap in the process. Before you cut make sure you only have the clear shrink wrap!
After doing that, if you find that the battery strap is kinda tight when you try to apply it, then add one thin metal washer under each post. You want the strap snug, but not flexing the chassis when you put the body clips in. Do this and you'll be all set for every cell on the market.
Darkseid is offline
