Schumacher Corner
It's not a completely new car. It's is going to be a copy of Teemu's car from the Euros. This car had all the things that guys have been doing to the car that help the performance. Things like the different chassis and suspension geometry. Better shocks and the new drivetrain. That being said, there's enough different about it that it would be cheaper to buy the EC car than try to convert the current car to the EC specs.
It is more of a asphalt car in the kit form, however there will be an optional chassis and top deck to make it a carpet car.
Originally Posted by bob33
i dont think they run foams but the track int like normal carpet its a rubbery thing (its on a indoor runing track) i never been ther befor, but the grip is suposed to b like tarmac.
MATTW have u been ther (don vally sheffeild)
jon 2 more things what shock length you runing on that set up u gave me
and lastly wer its says ackerman/bump middle/3mm whats this mean (i dnt no waht all this ackerman is lol)
thanks
thanks
The Ackerman is the difference in how much one wheel turns compared to the other. It's adjusted by moving the ball stud on the steering bell cranks. Use the middle hole on the bell cranks with 3mm spacer under the ball stud.
thanks alot jon, i understand that now lol. we have to use nosram vetec 24r preglued tyres/insert/rim as the controll tyres so will have to see what these are like as i never used them befor . thanks bob
Anytime.
Can anyone tell me what setup is this ? looks like a pro4 rear shock tower ???
Actually, I think that's a Yokomo shock tower. Jim Newberg was using Yok towers in Vegas and that's what they looked like. Jim, you want to chime in and correct me if I'm wrong.
I have run both the BMI chassis's and the Teemu chassis. I am currently running the Teemu. Seems better for me. I think it has more turn-in then the BMI because of the rearward battery position and the pendulum effect. My car does not get loose on turn-in, just better suited for me to my driving style and set-up.
I have a BMI rear tower, should I swap them ?
I would just so that you're more on the same page as most of the other drivers that are using them.
mi2
hi i was wondering if any one had a foam tire carpet setup i could use i have a mi2 with bmi lower and top deck and i have lower shock towers can any one help me.
regards matt
regards matt
Hi everyone. I just wanted to ask what your take on this is or if anyone has tried this out. I am currently running with a teemu chassis and shock towers. someone told me that I could try installing the stock riser plates together with the ones that came with the teemu chassis to increase my center roll rate. comments please.thanks
JP
JP
regards matt
regards matt
JP
JP
As to whether you should run it or not, it depends on the surface you run on.
This tower actuall has the camber link holes that are very similar to the newest generation BMI towers that were made for the IIC in Vegas. It also lowers the upper shock mounting holes a little more then the BMI. This tower works very well in high bite or with foams. If you are going to be running outdoors stick with the BMI towers.
And another thing, Roberto, if you have any questions on any thing on that car, feel free to ask. As Jon Kerr can atest to I completely rebuilt that car (yours) at Vegas
Later
Jim
