BMI's DB12R
#7458
so where can i get one of these smc lipo's? tower is out of them till july and how much do they run usually?
#7459
The new Thunder Power 1S will be out this week though:
http://www.aero-model.com/batteryDet...?id=race-sport
#7460
hey jason the new chassis looks sweet i really hope we get a new carpet track here on the east coast. my db12rr has been shelved since 360 speedway closed its doors and i cant get anyone to run 1/12 at our asphalt track oh well i will pick up a lipo chassis and maybe run it in cleveland this year
#7464
Hey guys, I will be posting the setup we came up with for the lipo chassis shortly.
If you would like to upgrade to the DB12RR with the lipo chassis, that is fine. The price is the same as with the 4 cell.
That really sucked to hear 360 closed down. Sal and Donny are great guys. I wish them the best
#7466
17.5 = 90-100mm
13.5 = 80-90mm
If you are running a speedo that advances the timing, shoot for the lower rollout, if you are leaving timing alone have been gearing up, shoot for the higher range.
#7468
The Rollout with 1s LiPo will be slightly dependent on your Speedo and motor timing, so here is the range I've seen most running:
17.5 = 90-100mm
13.5 = 80-90mm
17.5 = 90-100mm
13.5 = 80-90mm
#7469
#7470
hey mike. angled servo is more agressive on turn in. flat calms things down mostly on high bite carpet. if you are running on asphalt run it angled if you are on high bite carpet run it flat. you can run it angled on high bite carpet alot of us do but its agressive and requires some driving finesse but its worth it. i always have faster lap times with it angled hope this helps
