Speed Passion Cirtix Stock CLUB ESC >
Old 06-25-2010, 11:05 AM
  #226
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by skypilot
Katie is fast, cause since was 8 shes been running nitro. sportsman 17.5 is a breeze for her, that and the schumacher/sp combo works very good.
yeah she is fast...Kenny S is working on getting more speed to catch katie....lol
Goingfast is offline
Old 06-25-2010, 11:49 PM
  #227
got my combo 2 days ago thanks to speedtech rc so ill hopefully have it all going in a couple of days, does anyone know what the temperature we should aim to gear the motor at? mines a 17.5t
Inky is offline
Old 06-25-2010, 11:59 PM
  #228
Super Moderator
charlie_b's Avatar
Congrats on your purchase! WE have been gearing between 3.2 to 3.7 and have been temping at about 110*F. It is by far, the funnest racing i have had in a LONG time.
charlie_b is offline
Old 06-27-2010, 06:27 PM
  #229
Trader Rating: 61 (100%+)
I need a longer sensor wire. When can I get one. Is it ok to run the ESC and motor without the sensor wire.
mr240 is offline
Old 06-29-2010, 06:51 PM
  #230
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Hey guys, has anyone had trouble with this system using a 3pk with a spektrum module? The ESC is not reading the throttle during and after setup. It works well with an AM system but not the Spektrum and 3pk...
trdsupra88 is offline
Old 06-29-2010, 07:54 PM
  #231
TimPotter's Avatar
Trader Rating: 15 (100%+)
Whenever I have problems with ANY spektrum system. No matter the problem, I always make sure thier is a cap on the reciever... I had an issue on one system, and had to reset the model in the radio before it setup properly.
TimPotter is offline
Old 06-30-2010, 01:36 AM
  #232
razzor's Avatar
Have you reversed the throttle channel ?
razzor is offline
Old 06-30-2010, 08:21 AM
  #233
trdsupra88's Avatar
I havent tried to reverse the throttle, it is at normal now but shouldnt make a difference. It seems like they are just not communicating, Ive tried it with a different reciever as well and still wont work...
Old 06-30-2010, 08:22 AM
  #234
it makes a huge differance
mine didnt work till i reversed my throttle
give it a try see how it goes
sidecarphil1 is offline
Old 06-30-2010, 09:59 AM
  #235
trdsupra88's Avatar
Wow, normally I would say BS to that working but I was so fed up and ready to give that I did try reversing the throttle direction to reverse and sure as hell it worked. It makes no sense because it is all input but whatever works. I am currently geared at a 4.5 because the biggest pinion I found was a 35...
I guess you can believe everything you read on the internet.
I will be running on a Small to Medium track (fast laps of 10 sec. for touring), I will report my finding after the next race. Thanks for the fast responses guys...I RCTech...
Old 06-30-2010, 11:07 AM
  #236
not every one on forums bolws smoke up peoples arse
Old 06-30-2010, 11:18 AM
  #237
Trader Rating: 17 (100%+)
I am glad you get that figured out.
Also, thank you TEAM for the explaination.
BTW....this step is listed on page 5, step A on the Cirtix manual. Definitely for all the FUTUBA radio. Actually, I think all the Speed Passion ESC are all listed with the same step, since the 1st version SP GT V1.0.
BTW....our team did the race last SUNDAY on a 35 x 80 small carpet track (11 or so sec per lap, sub 10 for boost up 17.5)...our general gearing is 4~4.2. The bigger/more open the track, you can throw more gear....1 adjustment we did on the club spec is the DRAG braking...since our track is TIGHT and technical, I ended up using about 20% drag brake. That helps a lot.
Keep on racing....
Solara is offline
Old 06-30-2010, 11:46 AM
  #238
skypilot's Avatar
Trader Rating: 14 (100%+)
isn't that in the directions, I think it used to be if its not.
skypilot is offline
Old 06-30-2010, 07:08 PM
  #239
trdsupra88's Avatar
Either way I appreciate the help... I was at the end of my rope...
Old 06-30-2010, 07:25 PM
  #240
mrs lover's Avatar
Keep on racing....
where to adjust the drag brake?
mrs lover is offline
