Old 06-25-2010, 12:05 PM   #226
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by skypilot View Post
Katie is fast, cause since was 8 shes been running nitro. sportsman 17.5 is a breeze for her, that and the schumacher/sp combo works very good.
yeah she is fast...Kenny S is working on getting more speed to catch katie....lol
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 06-26-2010, 12:49 AM   #227
got my combo 2 days ago thanks to speedtech rc so ill hopefully have it all going in a couple of days, does anyone know what the temperature we should aim to gear the motor at? mines a 17.5t
Inky is offline   Reply With Quote
Old 06-26-2010, 12:59 AM   #228
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Congrats on your purchase! WE have been gearing between 3.2 to 3.7 and have been temping at about 110*F. It is by far, the funnest racing i have had in a LONG time.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 06-27-2010, 07:27 PM   #229
mr240's Avatar
Trader Rating: 61 (100%+)
I need a longer sensor wire. When can I get one. Is it ok to run the ESC and motor without the sensor wire.
mr240 is offline   Reply With Quote
Old 06-29-2010, 07:51 PM   #230
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Hey guys, has anyone had trouble with this system using a 3pk with a spektrum module? The ESC is not reading the throttle during and after setup. It works well with an AM system but not the Spektrum and 3pk...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 06-29-2010, 08:54 PM   #231
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Whenever I have problems with ANY spektrum system. No matter the problem, I always make sure thier is a cap on the reciever... I had an issue on one system, and had to reset the model in the radio before it setup properly.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 06-30-2010, 02:36 AM   #232
razzor's Avatar
Have you reversed the throttle channel ?
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-30-2010, 09:21 AM   #233
trdsupra88's Avatar
I havent tried to reverse the throttle, it is at normal now but shouldnt make a difference. It seems like they are just not communicating, Ive tried it with a different reciever as well and still wont work...
I cut my own hair ☆
Old 06-30-2010, 09:22 AM   #234
it makes a huge differance
mine didnt work till i reversed my throttle
give it a try see how it goes
sidecarphil1 is offline   Reply With Quote
Old 06-30-2010, 10:59 AM   #235
trdsupra88's Avatar
Wow, normally I would say BS to that working but I was so fed up and ready to give that I did try reversing the throttle direction to reverse and sure as hell it worked. It makes no sense because it is all input but whatever works. I am currently geared at a 4.5 because the biggest pinion I found was a 35...
I guess you can believe everything you read on the internet.
I will be running on a Small to Medium track (fast laps of 10 sec. for touring), I will report my finding after the next race. Thanks for the fast responses guys...I RCTech...
I cut my own hair ☆
Old 06-30-2010, 12:07 PM   #236
not every one on forums bolws smoke up peoples arse
Old 06-30-2010, 12:18 PM   #237
Trader Rating: 16 (100%+)
I am glad you get that figured out.
Also, thank you TEAM for the explaination.
BTW....this step is listed on page 5, step A on the Cirtix manual. Definitely for all the FUTUBA radio. Actually, I think all the Speed Passion ESC are all listed with the same step, since the 1st version SP GT V1.0.
BTW....our team did the race last SUNDAY on a 35 x 80 small carpet track (11 or so sec per lap, sub 10 for boost up 17.5)...our general gearing is 4~4.2. The bigger/more open the track, you can throw more gear....1 adjustment we did on the club spec is the DRAG braking...since our track is TIGHT and technical, I ended up using about 20% drag brake. That helps a lot.
Keep on racing....
Old 06-30-2010, 12:46 PM   #238
skypilot's Avatar
isn't that in the directions, I think it used to be if its not.
semi retired..
skypilot is offline   Reply With Quote
Old 06-30-2010, 08:08 PM   #239
trdsupra88's Avatar
Either way I appreciate the help... I was at the end of my rope...
I cut my own hair ☆
Old 06-30-2010, 08:25 PM   #240
mrs lover's Avatar
Keep on racing....
where to adjust the drag brake?
addicted
mrs lover is offline   Reply With Quote
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
Real Stock On Road Racing... Me_MrTyson Australian Racing 214 05-19-2010 06:06 AM
