Durango DEX210 Thread >
Like Tree80Likes
Old 04-05-2012, 08:28 AM
  #5206
Dog Runner's Avatar
Trader Rating: 23 (100%+)
I've got two full race days with the rear shock mod and, long story short, I'm gonna go back to the original as well. It was worth a try, but it wasn't noticeably better with the shocks on the back of the arm.
Dog Runner is offline
Old 04-05-2012, 09:56 AM
  #5207
Jmuck69's Avatar
Trader Rating: 14 (100%+)
+1 I tried it as well and went back to stock form. A +8mm chassis would be better suited.
Jmuck69 is offline
Old 04-05-2012, 09:59 AM
  #5208
Jmuck69's Avatar
Originally Posted by Raul Garcia
So I have been playing with the rear shock mod. I started with the hubs centered, shock on back, then I went to hubs foward, then I modified the rear arm to mount the shock on the front side of the flipped arm by adding a hole in the same position of the middle hole on the original spot. I played with the anti squat block also, switching from 2-3*. My conclusion for me is the car drives more consistent in the ORIGINAL layout with the shocks foward. I think the axle moves too much rearward, takes too much weight away from the rear of the car, shifting it foward, therefore decreasing the planted feel. I was consistently over rotating no matter the change in the car. I could not muster a better position than my qualifying postition in the main. That stinked....
The plus was, it looked longer on the track. It jumped a little better, but that was abot it. I think I could sacrifice for the stability.
I took some measurements of the arms with one stock on one side and one flipped on the other. It was only a gain of +.8 mm and the toe angles were screwy with the flipped arm. I have gone back to stock.
Jmuck69 is offline
Old 04-05-2012, 03:26 PM
  #5209
FrEaKiShTuNER's Avatar
Trader Rating: 200 (100%+)
Default Durango parts in stock?!?!?
I just posted this over in the DESC thread. I was at my LHS/track and they told me that they received a call from their "supplier" saying they now have Durango parts in stock.. So hopefully soon we will see the websites updated and parts available at our local level...
FrEaKiShTuNER is offline
Old 04-05-2012, 03:39 PM
  #5210
aloksatoor's Avatar
Trader Rating: 43 (100%+)
maan I just ordered a bunch of parts all the way from the UK from ebay
aloksatoor is offline
Old 04-05-2012, 03:46 PM
  #5211
MikeFriery's Avatar
Trader Rating: 19 (100%+)
i dont mean to burst your bubble, but if they are talking about a stateside supplier.. they are lying.
MikeFriery is offline
Old 04-05-2012, 03:48 PM
  #5212
Damn, hopefully shipping wasn't too bad!!
But hey, with the way things have been going. You'll probably still get your parts faster!!
Old 04-05-2012, 03:50 PM
  #5213
Hey no bubble to burst here.. I'm pretty used to the parts shortage. Just going on what they told me..
Old 04-05-2012, 04:11 PM
  #5214
aloksatoor's Avatar
No not much around 14 bucks. Used to buying from the UK, schumacher ships it and it arrives in a week with royal mail 5 GBP flat shipping. The ebay merchant prob used something more expensive!
Old 04-05-2012, 04:15 PM
  #5215
Rideordieguy1's Avatar
Trader Rating: 45 (100%+)
Cool Gear diff
Has any1 tried the optional geared diff in the 210? And was their any noticeable difference?
Rideordieguy1 is offline
Old 04-05-2012, 06:31 PM
  #5216
SavageCanadian's Avatar
Trader Rating: 60 (100%+)
Well I just ordered my new 210 today!! What is your guys opinion on the mid motor or rear motor. My track is around 70x140 and a cross between a 1/10 and 1/8. Traction is pretty good, which do you guys thing would do better?
SavageCanadian is offline
Old 04-05-2012, 06:54 PM
  #5217
Trader Rating: 520 (100%+)
You should try mm if you've never, if your track condition will allow it, they drive and especially jump really nice IMO. I would, but my tracks are pretty loose for the most part. I have mine in RM4 atm, but have yet to get it dirty in that configuration..
flame56mx is offline
Old 04-05-2012, 08:20 PM
  #5218
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
I'm getting some serious clicking from my drivelines. Always when I'm in the air or on a turn. Obviously from when they drop down. Anyone else have this annoying noise? Any possible solutions other than droop screws?
CHIZZLE is offline
Old 04-05-2012, 08:28 PM
  #5219
Trader Rating: 79 (99%+)
Chizzle, I experienced a similar problem. I had a clicking and locking noise coming at full droop too. Turned out to be damaged outer wheel bearings. They were toast. I replaced them and all of my noise disappeared. My diff feels like butter again.
Raul Garcia is offline
Old 04-05-2012, 08:39 PM
  #5220
Jmuck69's Avatar
Along with what Raul mentioned, I often clean and relive the pivot bushing in the axle. It's so easy to pull the axle and disassemble to clean. I usually do this before every weekend race. While the axle it out, check the bearings and replace if necessary.
Jmuck69 is offline
