Spool benefits?
#46
Originally Posted by Ben.C
We have discussion from spools to a certain female organ... Very nice...
Organ is the lower part !
Question: What's worst than having a mad dog on your Piano ?
....Ans: A Sick pussy on your organ ! (err, you do play musical instruments, dun you ?)
#47
Originally Posted by Ghostfit
btw, ......Ben, I believe that is not an organ ! should be a Gland.
But I have one at home ....!!
#48
Er.....I don't....
Okay, Okay ! ....SORRY ! ..deviated from the topic of Sick Spool and Mad One-ways !
#49
Thats it guys, stick to the subject ... Spools ...
#50
....Wat ? a Mad dog or the Sick pussy ?
Hmm...I meant an organ which you can play on....And yes,I do have a cute little mad dog at home...
Back to topic about benefits...Where there's benefits there's bound to be cons....They are: tires eaten up faster,drive shaft wear faster,If you run a lightweight spool,eg alu or delrin. prepare to change your drive cups often...
#51
#52
Originally Posted by v0rtex
Diff: Move one wheel forward, other goes backward
1-way: Move one wheel forward, nothing happens other side
Spool: Move one wheel forward, other goes forward too
Diff: Move one wheel BACKWARD, other goes forward
1-way: Move one wheel BACKWARD, other goes backward
Spool: Move one wheel BACKWARD, other goes backward
Basically a spool is like having a solid shaft between both wheels where they move the same direction at the same speed no matter what.
#53
Originally Posted by Entropy
Lets not forget that to use spools effectively you will need to brake. I know of some cases where someone's shottky diode fell off and he braked..
#54
Originally Posted by teamgp
Just to make it clear...
Diff: Move one wheel BACKWARD, other goes forward Which is the same thing he said...
1-way: Move one wheel BACKWARD, nothing happens other side Which is wrong... You spin one wheel backwards, the whole drivetrain spins.
Spool: Move one wheel BACKWARD, other goes backward Which is again the same thing he essentially said...
-Josh
#55
#56
Originally Posted by Pro4Capece
with a one-way, you move one wheel BACKWARD the the other wheel goes backwards. That's why it's called a one-way, b/t it only works one-way.
#59
coudln't the understeer you get going into the corner be reduced by using a one-way pulley, or do you have to lock the centre up to run a spool?
#60
Bad idea, cause then you have the disadvantages of both spool and oneway, you can't break and you have horrible turn in ...
If you like to run a spool than you should lock up the centre pulley, otherwise, when running a oneway , centre oneway drives even better ..
