Spool benefits?
Old 07-19-2005, 10:51 PM
  #46
Ghostfit's Avatar
Originally Posted by Ben.C
We have discussion from spools to a certain female organ... Very nice...
btw, ......Ben, I believe that is not an organ ! should be a Gland.
Organ is the lower part !
Question: What's worst than having a mad dog on your Piano ?
....Ans: A Sick pussy on your organ ! (err, you do play musical instruments, dun you ?)
Ghostfit is offline
Old 07-19-2005, 11:23 PM
  #47
Er.....I don't....
But I have one at home ....!!
Ben.C is offline
Old 07-19-2005, 11:44 PM
  #48
Ghostfit's Avatar
Er.....I don't....
....Wat ? a Mad dog or the Sick pussy ?
Okay, Okay ! ....SORRY ! ..deviated from the topic of Sick Spool and Mad One-ways !
Ghostfit is offline
Old 07-20-2005, 12:22 AM
  #49
Hick's Avatar
Thats it guys, stick to the subject ... Spools ...
Hick is offline
Old 07-20-2005, 12:43 AM
  #50
Hmm...I meant an organ which you can play on....And yes,I do have a cute little mad dog at home...
Back to topic about benefits...Where there's benefits there's bound to be cons....They are: tires eaten up faster,drive shaft wear faster,If you run a lightweight spool,eg alu or delrin. prepare to change your drive cups often...
Ben.C is offline
Old 07-20-2005, 02:21 AM
  #51
Entropy's Avatar
Lets not forget that to use spools effectively you will need to brake. I know of some cases where someone's shottky diode fell off and he braked..
Entropy is offline
Old 07-20-2005, 06:22 AM
  #52
teamgp's Avatar
Originally Posted by v0rtex
Diff: Move one wheel forward, other goes backward
1-way: Move one wheel forward, nothing happens other side
Spool: Move one wheel forward, other goes forward too
Just to make it clear...
Diff: Move one wheel BACKWARD, other goes forward
1-way: Move one wheel BACKWARD, other goes backward
Spool: Move one wheel BACKWARD, other goes backward
Basically a spool is like having a solid shaft between both wheels where they move the same direction at the same speed no matter what.
teamgp is offline
Old 07-20-2005, 06:01 PM
  #53
Ghostfit's Avatar
That fella needs MORE shottky diodes ! or one of them new Super Duper Diodes
Ghostfit is offline
Old 07-20-2005, 06:30 PM
  #54
josh69162's Avatar
Diff: Move one wheel BACKWARD, other goes forward Which is the same thing he said...
1-way: Move one wheel BACKWARD, nothing happens other side Which is wrong... You spin one wheel backwards, the whole drivetrain spins.
Spool: Move one wheel BACKWARD, other goes backward Which is again the same thing he essentially said...
If your one-way is set up so that your wheels spin FORWARD when you turn one wheel, you only have rear wheel drive.
-Josh
josh69162 is offline
Old 07-20-2005, 07:45 PM
  #55
ChadCapece's Avatar
with a one-way, you move one wheel BACKWARD the the other wheel goes backwards. That's why it's called a one-way, b/t it only works one-way.
ChadCapece is offline
Old 07-21-2005, 07:00 AM
  #56
teamgp's Avatar
Doh! My bad. I'll change the post.
teamgp is offline
Old 07-21-2005, 07:36 AM
  #57
Buck Nasty's Avatar
Here's a question, when building a spool do you line up the outdrives or offset them? Offset meaning when the spool is built one outdrive slot will be vertical and the other outdrive slot would be horizontal.
Buck Nasty is offline
Old 07-21-2005, 08:20 AM
  #58
Trader Rating: 29 (100%+)
new spools are built lined up....but since the right and left side are totally independent from each other it might not matter.....but its just as easy to build lined up.......
Mdoc is offline
Old 07-21-2005, 09:26 AM
  #59
Ali Graham's Avatar
coudln't the understeer you get going into the corner be reduced by using a one-way pulley, or do you have to lock the centre up to run a spool?
Ali Graham is offline
Old 07-21-2005, 01:34 PM
  #60
Martin Hofer's Avatar
Bad idea, cause then you have the disadvantages of both spool and oneway, you can't break and you have horrible turn in ...
If you like to run a spool than you should lock up the centre pulley, otherwise, when running a oneway , centre oneway drives even better ..
Martin Hofer is offline
