Xray NT1
#4501
hello,
its a KM racing rotor
http://www.km-rc.com/oscommerce/cata...9affc90ac67bcc
also check the capricorn one, i've been usin it for a while and its holding up
like a champ
http://www.capricornrc.com/os_capric...roducts_id=113
the price gap is huge between the 2 but i think you get what you pay for.
KM Rotor= 6 dollars
Capricorn Rotor = 60 dollars
cheers
Ali
like a champ
KM Rotor= 6 dollars
cheers
Ali
#4502
Congratulations to Thomas Günsel winning the german championship with NT1 and Orcan/Novarossi!!!
First 5 cars all XRAY NT1
The car was great last weekend at the Türkheim track. The only car that had no problems with traktion roll on this high bite track.
1. Thomas Günsel NT1 Orcan LR3
2. Simon Balk NT1 Orcan LR3
3. Michael Heinrich NT1 Orcan LR3
4. Dirk Wischnewski NT1 Orcan LR3
5. Erik Dankel NT1 Orcan LR3
#4503
Hello from France,
RB T9RC powered NT1 are again French National Champion in A class and also in B Class !!!!
Last round see the domination of the NT1 with a full XRay podium...
Au revoir.
Au revoir.
#4504
hello,
like a champ
KM Rotor= 6 dollars
cheers
Ali
like a champ
KM Rotor= 6 dollars
cheers
Ali
#4505
#4507
I'm a little old school here, so I have an alternative for you. I've been using the same process here in the XRAY T1FK'05 FAQ section for several years now. Here are a few things to do a little differently than what is written, since the shock assemblies are slightly different now:
* On step 11 when you first start threading the top cap on and the excess oil starts pumping out the sides, slowly tighten the top cap down. This allows most of the excess oil to bleed out and lessens the time needed for bleeding from the bottom.
* On step 11, disregard the statement about not tightening the top cap too much. The newer shock parts and bladders work perfectly with the top cap tightened down firmly. This also ensures that the top cap does not unscrew when you are adjusting the aluminum spring collars.
* On step 12, after you turn the shock upside down and let it sit for the moment (to allow any air bubbles to rise up), and unscrew/lift up the bottom cap, only let the air bleed out for 10 seconds and then quickly screw the bottom cap back on. You should end up with about 100% rebound after the first time of bleeding. If you want less rebound, unscrew/lift up the bottom cap again for another 10 seconds. Keep doing this until the rebound is right. It doesn't take any time at all if you let enough excess oil bleed out while slowly tightening the top cap.
Note: I do not pump the piston at all while bleeding from the bottom cap. I just unscrew the cap and let the oil bleed out for 10 seconds at a time.
also read this m8
http://forum.teamxray.com/viewtopic....ghlight=#60654
#4508
EURO Champion Edition
#4509
#4510
New LW brake disk
#334111
Is it a new option disk ? It's included in the 09 EC Edition.
#4511
Taking Pre-Orders on NT1 EC
We are currently taking Pre-Orders on the New NT1 EC Limited Edition. The new part number is XRA330002
To find our site go to google and type TQ Hobbies
Please feel free to email us @ [email protected]
#4512
Diff oil maintainence
Guys how can you tell you need to replace your diff oil with a fresh batch with having to open the diff and damaging your O ring?
#4513
#4515
And gasket sealant might spill over inside the diff casing if people do messy job..... I rather keep it original as per designed by xray.
