Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 03-23-2010, 11:42 AM
  #8521
Trader Rating: 35 (100%+)
I found this photo on the Tamiya website. It's the 416X chassis of one of the factory drivers.
I'm looking specifically at the carbon fiber piece used as a battery brace. Looks like a custom piece to me. I wonder where I could find a sheet of carbon fiber?
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-416x-.jpg
Geppetto is offline
Old 03-23-2010, 02:45 PM
  #8522
Johnny Wishbone's Avatar
I use 2 pieces of K&S aluminum square tubing that you can buy at most hobby shops, the tube is about 2.5mm thick and I have it run the length of the chassiss from the motor mount to the servo mount. Its just shoe gooed in and when you use 2 of them side by side it will move your Lipo battery out to the edge of the chassiss, almost perfect, for weight balance. It makes it really easy to tape your batteries in and there is no chance of them moving into your belts.
Johnny Wishbone is offline
Old 03-23-2010, 03:07 PM
  #8523
Thanks for the suggestion. Actually, others have suggested using lead weights.
I just like the clean, near factory appearance of the carbon fiber.
Geppetto is offline
Old 03-23-2010, 03:24 PM
  #8524
Nice thing about my method is you'll never knock a weight off from a side hit. Some guys that do this paint the tubing black to blend in with the chassiss, it also gives proper belt clearance if you do the belt flip mod on your car. Of course the CF is a nice piece too.
Old 03-23-2010, 03:57 PM
  #8525
I just had an idea... I could use your method, and cover the tubing on the exposed sides with CF decal. It would certainly cost a whole lot less, yet still look good!
Geppetto is offline
Old 03-23-2010, 07:51 PM
  #8526
M-Technic's Avatar
Trader Rating: 15 (100%+)
How often are you guys having trouble with your batteries moving? I have never had my battery shift, nor has my tape ever broken. It doesn't seem like much of an issue to me.
M-Technic is offline
Old 03-23-2010, 08:18 PM
  #8527
Not a problem for me either, but I have one Lipo pack that has a dent in it from being t-boned, and it was a hard enough hit that it bent the aluminum bars I mentioned above. It probably depends on how your mounting your stuff as well, if your using a lipo plate and double side tape or if your packs have the locator bumps, and of course how far out your trying to move the lipo for balance.
Old 03-23-2010, 10:52 PM
  #8528
CraigM's Avatar
Trader Rating: 34 (100%+)
Locator bumps seem to be a bit out of favour with the manufacturers at the moment, but I never had a problem running my old 28C SMCs without them. Just make sure you file the tape slots real good and you wont have a problem
I just picked up my smokem chassis today. It feels slightly thicker than the stock chassis and it has less cutouts so I'm expecting it to be a bit stiffer out on the track, it looks the business though and I love how narrow all these lipo decks are
CraigM is offline
Old 03-23-2010, 11:07 PM
  #8529
StevenOlsen's Avatar
i got mine yesterday, and it looks really nice, the chassis is 2.25 mm so its a little thicker then the stock one.
steven
StevenOlsen is offline
Old 03-23-2010, 11:40 PM
  #8530
HK416's Avatar
steven
I too received my smokem chassis today , can't wait to test it tomorrow. Got the steering brace too. Please advise if you encounter any adjustments or setup changes.
HK416 is offline
Old 03-24-2010, 12:13 AM
  #8531
Senna Racing's Avatar
Pics please
Senna Racing is offline
Old 03-24-2010, 12:20 AM
  #8532
TryHard's Avatar
Originally Posted by Stein Tumert
For asphalt, HPI blue, silver and gold springs
You can throw HPI Pinks into that mix too, as they sit between Silver and Gold
HiH
Ed
TryHard is offline
Old 03-24-2010, 01:21 AM
  #8533
Cant seem to find the part number for the HPI spring cups and shock ends needed to run the HPI springs. Can any one shoot me the number?
Thanks a million,
Kody
Kody is offline
Old 03-24-2010, 01:26 AM
  #8534
Never mind my post above... Found it. 73510
Kody is offline
Old 03-24-2010, 03:03 AM
  #8535
Mistique's Avatar
Originally Posted by ijat
Thanks malkiy.. does it fit nicely into 416we? or do i need any modification on the bearing housing or bulkhead?
i heard that the front one way set for DB01 can also fit into 416we. does anyone can confirm on this?
http://www.tamiyausa.com/product/ite...oduct-id=54017
Ijat..
macam mana?? dah test ke oneway diff tu??
ok ke?? brape kalau nak beli??
ko dari mana?? kalau free pm laa aku!!
Mistique is offline
