Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 03-05-2010, 08:41 AM
  #8371
jonest's Avatar
Smoke em's chassis should be avail by end of next week.
Have you ordered yours? I had!!!
jonest is offline
Old 03-05-2010, 09:36 AM
  #8372
TryHard's Avatar
Originally Posted by dodo View Post
any news on price, Ed?
Not yet I'm afraid... First one is being cut now, and that's the proto, so I can check screw positions and general flex properties.... And maybe even give it a track test Should have it back next week, so might be able to give more of an indication after then
Ed
TryHard is offline
Old 03-05-2010, 09:55 AM
  #8373
MikeR's Avatar
Trader Rating: 15 (100%+)
Default 416XL
Originally Posted by veecee View Post
Exotek is listed as coming soon. So looks like a wait on both...
Hello Gentlemen,
Ours will be released Monday. Had to add a few days because we will have 2 versions of 416XL Lipo Chassis available.
The 1st version will include the steel weight battery holders for $84.95 and the 2nd version will have carbon fiber battery holders for $74.95. The CF version is recommended for those that need to run below 1400g of weight. The steel version is for heavier weight limits such as ROAR.
I'm very surprised by the email response so far and have ordered a 2nd batch to be made up for this month as it appears the first batch will be sold out quickly next week.
Thank you all for your support and happy racing!
MikeR is offline
Old 03-05-2010, 01:45 PM
  #8374
Originally Posted by MikeR View Post
Hello Gentlemen,
Hi Mike
This might be a daft question but how do you tape the packs in to this chassis? I couldn't see from the pictures where it would run.
Or do you have to use the battery bar?
Ade
ade_7 is offline
Old 03-05-2010, 01:59 PM
  #8375
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by ade_7 View Post
Hi Mike
Ade
there are two small plates that screw onto the top of the battery weights.. and the battery tape ONLY goes across the top of your battery.
so you can set tweak without having to remove your battery tape.
Hebiki is offline
Old 03-05-2010, 02:43 PM
  #8376
MikeR's Avatar
Hibiki is correct- the included tabs are what you attach the tape pieces to. We suggest you loop a piece of tape on each tab and then bridge a long piece of tape over the battery and from tab to tab. You then only need to replace the long center section as needed. This system does not put tape under the chassis thus preventing interference when you reset your tweak which you should be checking after every run.
We do offer the custom battery strap if you want to omit tape entirely
MikeR is offline
Old 03-05-2010, 02:47 PM
  #8377
94eg!'s Avatar
Trader Rating: 17 (100%+)
Your loosing me on this one. A picture would really help...
94eg! is offline
Old 03-05-2010, 03:38 PM
  #8378
Hebiki's Avatar
here you go....(this is the exotek chassis on the TC5.. this is NOT the 416 chassis )
Hebiki is offline
Old 03-05-2010, 03:54 PM
  #8379
MikeR's Avatar
Sorry about that, it is better explained in the instructions.
Thanks again Hibiki!
More pics here of TQ Christer Anderssens car;
http://events.redrc.net/event-galler...cup/?nggpage=6
MikeR is offline
Old 03-05-2010, 05:06 PM
  #8380
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Just wondering if there is an optional or different diff plate (not 416x) people are using? It looks like in this pic that Marc R might be using something different as the plates look like they go past the outdrive.
Any ideas or advice?
Latest ETS pic
DirtyDog3375 is offline
Old 03-05-2010, 06:46 PM
  #8381
sonic31's Avatar
Trader Rating: 6 (88%+)
dirtydog, im looking at that pic and its all stock
sonic31 is offline
Old 03-05-2010, 10:47 PM
  #8382
Default Front Rear Susp Block
the front rear suspension block tends to bent easily, will this #54174 RC TA05VII Separate Sus Mounts - Version II (1C-1XC) can be use to replace the one piece 1C susp block
http://www.tamiyausa.com/product/ite...oduct-id=54174
leonardiw is offline
Old 03-05-2010, 10:51 PM
  #8383
syndr0me's Avatar
Trader Rating: 32 (100%+)
Yep, that will work on your 416, and definitely seems to stand up to bending better.
syndr0me is offline
Old 03-06-2010, 03:20 AM
  #8384
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by DirtyDog3375 View Post
I've got that same tape
I'm looking forward to trying the smokem chassis, should have mine soon too
CraigM is offline
Old 03-06-2010, 05:18 AM
  #8385
Vicko's Avatar
Trader Rating: 14 (100%+)
anyone have an pic of the smoke chassie?
also Ed well you post an pic of your chassie also??
Vicko is offline
