Durango DEX210 Thread
#7951
I had the same issue. The two washers are different sizes on purpose. From what I have read here you should put the tighter one on first. I had a tough time getting the tighter washer on but it eventually slid over the bolt if you get it just perfect.
What was the first thing that brought you to a halt?
#7952
#7953
Thank you for the info
Are you using a vinyl chassis protector on your carbon? Is it wearing decent if not? Did you need to glue the edges or anything like that? We had Vantage chassis's on our Revo's and they were great. Just hoping for the same with this buggy. But the Revo's had skid plates, which is why I ask about protection. Lots of questions!
What is the wait time?
Also, good luck with production!
#7954
After reading the forums i was concerned about the stock ball cups. So far i have not had a ball cup pop off while driving. The problem i did have was a cracked front ball stud.
I tried to take off a front ball stud to add a washer and it broke into two pieces. Never had that happen on any car before.
#7955
I raced my new 210 this past Sunday and poped every ball cup at least once. The angled ones on the rear could be pressed on and pulled back off with little to no effort. I also found one of the balls had crushed. I've never had to replace so many ballcups while at the track untill running this car!!!
I also broke a front hub carrier but that was from a weird crash.
The 2 wheel buggy I replaced with my Durango was a B4.1. It took me several track days to get that car perfect. I was able to make the 210 feel as perfect in under 3 hours.
I'm sold on this brand.
After buying and installing the Lundsford turnbuckle kit this car will be perfect.
#7956
Except that it deserves a better driver!
Haha...jk...
Haha...jk...
#7958
Is the spur or the pinion touching? What gearing? When Cush ran blinky 17.5 last year I had to dremel the gear cover a bit around the pinion for gear clearance running 75/35, or you may be able to just slide the pinion towards the motor plate a bit. If it's the spur rubbing, then I would think something is assembled wrong- unless you have an AE gear on there. I've seen an AE gear be a little wider and rub the cover.
#7959
Did you by chance look at this: http://www.team-durango.com/in-the-p...rticle_id=4915. The concept of not having to pop a ballcup to make a camber link adjustment is really useful, and worth giving another shot. We still use stock cups on all our TD cars and very rarely pop one off.
In addition to what the article says, I like to enlarge the hole the ball cup (where the link threads in) with an 1/8 drill bit, about 3/16-1/4in deep. This allows the shank to move freely if you run a short camber link position.
#7960
The people who have ball studs breaking....are you replacing with Durango studs or Jconcepts studs listed previously in this thread?
I take possession of my 210 this week and not sure if my LHS is fully stocked with Durango parts yet. But he is plentifull with Jconcepts parts.
Thanx.
Thanx.
#7961
So people are already saying the composite plus 8 chassis is too soft to get the carbon composite Durango one when available. How much of this is speculation being neither are even out except the rtr? Back I. The day the associated drivers all traded away the carbon composite chassis for the plastic one because stiffer isn't always better. Just wondering...... The rtr market generally isn't serious racers so broken chassis in that demographic doesn't really concern me, it's all the conjecture about a part not even available that has me thinking.....
#7962
Thanx.
Thanx.
#7963
Air8- I love my DEX210. I will be in Hutch this weekend racing if you want to drive mine. I have been running the stock ball cups and have a couple of times an issue but on wrecks where I should. I am going to put a lunsford kit on mine...just because I like it not because I think I need it. Buggy works well on the clay track in Hutch. I am sold on it!
#7964
For those of you breaking front ballstuds, i broke 2 in a row before i realised what caused it. When you tighten the stud down and try to retrieve your hex driver from the stud, dont wiggle it trying to get it out. The ball is a 2.5mm hex and it makes the walls thin and the wiggling of the driver cracks it. Its not a problem on the track, its just a problem if you arent careful when wrenching.
The tc5 ballstuds are what i run on my desc410r and i will be putting them on my dex210 aswell so i can run my fancy Flo yellow jcon ballcups lol
#7965
