Tekno RC ET410 Thread >
Like Tree464Likes
    Hide Wikipost
Old 03-02-2020, 09:56 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC ET410 Thread
Last edit by: rustyus
Welcome to the ET410 Wiki page.
  • 95% parts compatibility with the EB410 4WD 1/10th scale buggy.
  • Updated 3mm 7075 CNC chassis and revised A and B hinge pin braces.
  • 13mm hard anodized threaded shocks with locking spring perches.
  • New 32 pitch spur gear for ultimate durability
  • 3.5mm shock shafts with revised dual guide x-ring cartridge.
  • 7075 CNC machined adjustable hinge pin brace system.
  • Three high volume fluid-filled adjustable differentials.
  • Lightweight 7075 tapered center driveshafts.
  • Quick access to differentials and maintenance friendly layout.
  • Captured CVA front and rear driveshafts with heavy duty 6mm stub axles.
  • Fully ball raced reverse bellcrank steering system.
  • Uses 1/10th AE Offset Stadium Truck or Traxxas Slash Short Course offset wheels.
For you guys all discussing what power plant to run, I would take note of the following statement from Matt W.
Matt - Probably would recommend a 10.5 for something similar to 13.5 in a buggy. I personally run a 6.5 in it and it’s pretty fast. Pro4 4600 will run in it but it has a lot of power and will need to be turned down in the esc.
Parts Needed to convert from EB410 to ET410
Pin Replacement Tool options
Inner Hinge Pin Inserts- Degrees of Adjustment
Upgrades:
Print Wikipost
Old 05-19-2019, 05:56 PM
  #871
platgof's Avatar
I am using an Orca that did great on the B64, but not on this. I guess I need the HT Tekin 6.5 for sure, but the Pro2 5100 could be the beast I need? The 6.5 would be considerably cheaper though. The set up sheet is Jesse Munn.
platgof is offline
Old 05-20-2019, 09:24 AM
  #872
sea1swk's Avatar
Originally Posted by suzukipro
I converted an ET into an SC410L using a cobra chassis, it is lot more nimble than my SCT410.3. I have since pulled the front diff, driveshafts etc and dropped a 17.5T / B64 slipper in it to try out in stock 2wd Short Course. I need to add weight to the rear to make minimum weight requirements in both configurations.
Mine looks so close to this. 20g steal D block. Exotek Rear Brass 56g. then Two Brass plates on each side in the front (2 sets of 26g and 43g, AE Brand). I had to add about 200g to make min Roar 4x4 SCT weight. Nimble is a great word to describe in.
sea1swk is offline
Old 05-20-2019, 01:49 PM
  #873
I was using the Pro2 5100. It had great top end but didn't have the bottom end I wanted. This gave it more of an on/off feel. I switched to s Hobbywing 3800 at half the price and couldn't be happier. Running 19 or 20 pinion and equals the speed of the Pro2 with a lot more bottom and mid range
m59y is offline
Old 05-20-2019, 03:05 PM
  #874
suzukipro's Avatar
Trader Rating: 33 (100%+)
I was very impressed with how well it handled and jumped along with how easy it was to drive consistent fast laps in 4x4 trim. I'm hoping it will work as well in 17.5 (stock) 2wd SC, but I'll have to wait until this weekend to get some laps in and be able to test some different setups. Gearing is looking like 69/30-33 at the moment, but I'm open to advice or suggestions anyone has.
suzukipro is offline
Old 05-20-2019, 04:14 PM
  #875
do you have a link for the Cobra chassis?
MaX-D is offline
Old 05-20-2019, 04:20 PM
  #876
platgof's Avatar
M59Y, what esc are/were you using with the 5100? I just ordered the 5100 before reading your comments.?
platgof is offline
Old 05-20-2019, 05:10 PM
  #877
suzukipro's Avatar
I purchased an unused one from someone on FB, but here is the FB page for cobra racing https://www.facebook.com/groups/539051429511100/ Send them a message and they should be able to help you out. Here is another great place to find out info on these conversions be it 2wd or 4wd https://www.facebook.com/groups/1890104114538545/
Old 05-20-2019, 07:11 PM
  #878
wrightcs77's Avatar
Trader Rating: 551 (100%+)
That was me you bought the chassis from. Glad you are enjoying it.
wrightcs77 is offline
Old 05-20-2019, 07:35 PM
  #879
suzukipro's Avatar
Thanks again, it's working out great so far and been a fun project to work on!
You also get credit for the carisma front bumper as it is an improvement over the SC5M front bumper people were using!
Old 05-20-2019, 10:38 PM
  #880
I am using a HW XR10 Pro 160A ESC
m59y is offline
Old 05-21-2019, 03:31 AM
  #881
rustyus's Avatar
Default Wing That Was Meant To Be
After putting up with repairing the lexan wing, and running the truggy without one, something had to be done.
rustyus is offline
Old 05-21-2019, 06:49 AM
  #882
Trader Rating: 35 (97%+)
Those SWorkz wings are the way to go! I don't think I even used the lexan wing at all, knowing it would just get destroyed after only a few hits.
Tbuggy is offline
Old 05-21-2019, 07:44 AM
  #883
so I got my et410 yesterday, bought it from a guy on facebook on the tekno buy/sell group, great truck that was never ran. he had it converted to front mount rear shocks, I want to run a Finnisher body so I converted it back to rear mounted shocks, after getting it all back together, my spring and spring cups are barely kissing the driveshaft/dog bone on both sides of the truck, I ending up making a pair of plastic spacers to get the needed space, anyone else have this issue? I went by the manual and verified everything is put together properly
scott_0 is offline
Old 05-21-2019, 07:54 AM
  #884
The EB does it too. You can solve this with a 1-2mm spacer.
scott_0 likes this.
Tbuggy is offline
Old 05-21-2019, 09:29 AM
  #885
sea1swk's Avatar
ooo, Carisma front bumper? what would that be? I'm using tbone Racing front and rear eb410 bumpers. But the front is about 1/2 inch under Roar rules for with. Rear is great. sc6.1 bumpers are not a great fit.
sea1swk is offline
