HPI R40 Nitro Car Forum >
Old 10-31-2005, 06:50 PM
  #9016
ogreasurada's Avatar
Hey, HarkonnenD, are u VTECHSaboteur from FRR?
ogreasurada is offline
Old 10-31-2005, 07:04 PM
  #9017
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally Posted by ogreasurada
Just wondering where does the Rx battery go in the 05 R40?
left hand side////
fastharry™ is offline
Old 10-31-2005, 10:46 PM
  #9018
To me it seems that the battery is trapped inside?
Old 11-01-2005, 01:10 PM
  #9019
Greenbox's Avatar
u know the graphite plate that replaces the exsisting reciever cover? take that off to have access to the battery.
Greenbox is offline
Old 11-02-2005, 09:55 AM
  #9020
scoobydo's Avatar
So whats the $$$ damage? And where can you get it?
scoobydo is offline
Old 11-02-2005, 12:37 PM
  #9021
Greenbox's Avatar
its estimated at 299 euros buts its not instock yet so....
Greenbox is offline
Old 11-02-2005, 09:09 PM
  #9022
What are the chances of us getting the Hara Edition here in the US?
B.LaFrance is offline
Old 11-03-2005, 03:56 AM
  #9023
Artificial-I's Avatar
Trader Rating: 17 (100%+)
100% , because thats the version we are getting here. We already have the hara pro4.
This should be released or announced shortly in the US. Im guessing in 1 month you might start seeing these in stock in stores.
Artificial-I is offline
Old 11-03-2005, 12:09 PM
  #9024
This is a picture of Surikarns car i took while at the HPI winternats adn take a look at the batteries placement were the reciver was.
Brett.w is offline
Old 11-04-2005, 05:02 PM
  #9025
onnetz's Avatar
anybody know a rain dance to make it stop?
I want to run my R40....... :-)
also.. is it just my eyes or are those 26mm foams on the rear in that pic?
onnetz is offline
Old 11-05-2005, 08:05 PM
  #9026
bummy's Avatar
Default need help with 2 speed.
well i got 04 r40 with nova rossi nsr 12 s3. and suitable pipe.
but i have never been able to get it into second.
any reason's why? or can sum one give me sum clutch specs so i can adjust it?
also on the clutch bell housing thing that comes with the kit, i was driving it around getting it set up, and the first gear came off? does anyone know why? it seems to have stripped the thread on the clutch bell housing that it screw onto.
has any one had this problem. with there.s cheers
bummy is offline
Old 11-05-2005, 08:08 PM
  #9027
bummy's Avatar
also the tail end seems to be very slippery, does anyone have any sugestions to make it stick more, maybe iam using wrong diff oil? should i use grease what weight should i use.
my tyre choice is fast tyre's . great tyres/ but it just slides out so easy under power you give it a bit and it just spins around.
iam using the standard oil that comes with the kit, in that little bottle thing front and rear, i took the one way out, as the track i race on is very tight, and need full braking coming off the straight. cheers.
bummy is offline
Old 11-05-2005, 08:21 PM
  #9028
bummy's Avatar
i wonder why he swapped the batter and reciever around? maybe he only had a hump pack on hand? i cant think it would make it handle better you want the weight in the middle.
bummy is offline
Old 11-06-2005, 04:08 AM
  #9029
The 2005/Hara has a solid lower chassis , no battery door underneath. Thats one reason. The other is the gas tank I believe takes up that space now.
  #9030
Try some twister tires , 37 all around.
