Mugen MTX-3
#2656
Airtronics
What happened to the Ofna cars.
#2657
Re: Airtronics
But he had some problem, Not realy sure what it was.
#2659
Front Diff Leaking
hmmm,seems like i still have a problem with my front diffi have all the peices to the diff. now and i want to know the best way to build it without it leaking,without the use of airseal(because i know it doesn't work for me).should i use the stock screws or should i buy some longer ones?thanx
#2660
You may have put to much in or you did'nt use a gasket to seal the two halfves
put all of the gears in the bigger half of the diff together first,
then put enough lube into the diff so that it just covers all of the gears, then stand it up on end so that all of the lube settles to the bottom, then apply the other half with the gasket and fasten it together with the 4 screws
#2661
Re: Re: Airtronics
Originally posted by tennessee
I believe they're was only 1 in the main "Jose Casass"
#2662
Re: Front Diff Leaking
Also, like Tennessee said, you may have put too much lube in there too.
#2663
i did exactly what the manual says (fill up to where they cross)i think my case is stripped.
#2664
Hi
has any of u guys uses a fifth body post for the MTX-3.
What are the uses? any feedback on it?
just been to K-factory website, saw the 5th body post hop-up but
was thinking if it is really good.
thanks for your feedback.
#2665
Works great
It keeps the body from flexing where the bottom of the window meets the hood
#2668
I went back to the stock settup for the last round of qualifying
I did lay the front shocks down all the way.
I went 1 hole up on the rear shocks
37 fronts 62mm 40 rears at 62.5
I used the old stratus body
Droop was 2 in front and 6 in rear
Sway bars were both flat
16-20 pinion 43-47 spurs
61215L RD-LOGICS 1 piece pipe
Ran the same in the main except 45 degress on the front swaybar
#2669
Mugen finishes 1-2-3 at airtronics race
Race results click here www.revrace.com
i really want an MTX3 but the parking lots i run on arent the cleanest.. any suggestions?
#2670
Shaft drive HPI?????
