Old 03-29-2003, 08:59 PM   #2656
Default Airtronics
What happened to the Ofna cars.
thebutcher is offline   Reply With Quote
Old 03-29-2003, 09:06 PM   #2657
tennessee's Avatar
Default Re: Airtronics
I believe they're was only 1 in the main "Jose Casass"
But he had some problem, Not realy sure what it was.
tennessee is offline   Reply With Quote
Old 03-29-2003, 10:08 PM   #2658
David Joor's Avatar
R/C Tech Charter Subscriber
kaozzlord - nice spam
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 03-29-2003, 10:55 PM   #2659
Default Front Diff Leaking
hmmm,seems like i still have a problem with my front diffi have all the peices to the diff. now and i want to know the best way to build it without it leaking,without the use of airseal(because i know it doesn't work for me).should i use the stock screws or should i buy some longer ones?thanx
shortyboy is offline   Reply With Quote
Old 03-29-2003, 11:08 PM   #2660
tennessee's Avatar
You may have put to much in or you did'nt use a gasket to seal the two halfves
put all of the gears in the bigger half of the diff together first,
then put enough lube into the diff so that it just covers all of the gears, then stand it up on end so that all of the lube settles to the bottom, then apply the other half with the gasket and fasten it together with the 4 screws
Old 03-29-2003, 11:54 PM   #2661
Default Re: Re: Airtronics
Just givin Jose a little stab. Good race Jose....
Old 03-30-2003, 12:51 AM   #2662
FREAKAH's Avatar
Default Re: Front Diff Leaking
Airseal is too thin and runny. You need automotive silicone(black or clear will do). You also need to apply the silicone to both sides of the gasket and make sure all the parts are clean.
Also, like Tennessee said, you may have put too much lube in there too.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 03-30-2003, 05:05 AM   #2663
i did exactly what the manual says (fill up to where they cross)i think my case is stripped.
Old 03-30-2003, 12:15 PM   #2664
Vinyard's Avatar
Hi
has any of u guys uses a fifth body post for the MTX-3.
What are the uses? any feedback on it?
just been to K-factory website, saw the 5th body post hop-up but
was thinking if it is really good.
thanks for your feedback.
Vinyard is offline   Reply With Quote
Old 03-30-2003, 12:46 PM   #2665
tennessee's Avatar
Works great
It keeps the body from flexing where the bottom of the window meets the hood
Old 03-30-2003, 01:23 PM   #2666
Trader Rating: 2 (75%+)
PUNISHER is offline   Reply With Quote
Old 03-30-2003, 01:27 PM   #2667
Suspended
Trader Rating: 28 (100%+)
Tennessee
Can you reveal your airtronics setup for us?I am from n.Cali and wanted to race Revelations and thought why not ask.
Thanks!
racenut123 is offline   Reply With Quote
Old 03-30-2003, 02:10 PM   #2668
tennessee's Avatar
I went back to the stock settup for the last round of qualifying
I did lay the front shocks down all the way.
I went 1 hole up on the rear shocks
37 fronts 62mm 40 rears at 62.5
I used the old stratus body
Droop was 2 in front and 6 in rear
Sway bars were both flat
16-20 pinion 43-47 spurs
61215L RD-LOGICS 1 piece pipe
Ran the same in the main except 45 degress on the front swaybar
Old 03-30-2003, 02:18 PM   #2669
Mugen finishes 1-2-3 at airtronics race
Race results click here www.revrace.com
the guy on the left is really stylin with those shorts.
i really want an MTX3 but the parking lots i run on arent the cleanest.. any suggestions?
Jfawwaz is offline   Reply With Quote
Old 03-30-2003, 02:28 PM   #2670
tennessee's Avatar
Shaft drive HPI?????
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
