TLR TEN-SCTE 2.0 Kit Thread
#2926
No I've built a few diffs and though tight it works. But I was asking if the titanium screw kit had different diff screws. I'm building this kit for Saturday and getting some of the more tedious parts out of the way is clutch. So if there aren't Ti screws for the diff ill build em tonight
#2929
Today my samsung tv wouldnt power up, did some googling, found out its 2 of four capacitors that was the prob, a while back i bought a bunch of capacitors to make glitch busters, they had the same specs as the ones i needed to replace, thank goodness for our hobby it enabled me to be able ro have the skills needed to solder new capacitors to my tv lol
#2934
2 = fix
I really don't care about the absent receiver box. Anybody who races and does multiple classes would ditch the thing anyways. My grip is the same cheap plastic as the RTR (and fasteners) I wanted the 22 stuff. The first run the rear carriers fail and also the steering arms just failed, cracked! I notice these are both must have upgrades but Losi still uses same old stuff and that is what everybody ends up replacing. I don't want replacement parts from HH I want parts that do not fail. Version "2" should = improvement and not require the number 1 product being upgraded by a aftermarket companies.
#2935
#2936
#2938
FYI the tc3 and rpm receiver box are too big. Still looking for one small enough to fit behind the servo.
Any of you know if HPI Racing Desert Trophy Trucks has a small enough receiver box?
http://www3.towerhobbies.com/cgi-bin...&I=LXCHTX&P=ML
Maybe go to a thiner or no front sway bar. Either that or a lighter spring but id play with the sway bars first. You could also try and free up the rear maybe but thats depending on lots of things like what the layout is like and how it performs everywhere else on the track.
#2939
