Speed Passion Cirtix Stock CLUB ESC
#646
Switched from 17.5 sp v3 to a 17.5 Ballistic. Ran a couple of times. The next day, system does not run. When I pull the throttle it wants to reverse, then dies. Did I fry the esc? I have been using the esc for months now with the v3 combo. It makes a high pitched noise when I pull the throttle.
#647
Is there a new combo with an updated 17.5 V3 motor? The kits I was about to order (and the one I have in my buggy right now) are V2 motors. Just want to know what the latest and greatest are.
Thx.
PS. Ran my buggy again for 4 hours today and I'm always impressed with how this things performs. I'm tempted to order another for my SC10 and put the Tekin on the shelf for a while.
Thx.
The current V2 Ultra Sportsman does not recommand to adjust the end bell timing, but it is possible to do so.
#648
When runnning a rx battery, can we run the Cirtix asis, or do we need to unhook/cut the red servowire from it?
#649
If you are indeed trying to run it on 1S with the Cirtix Club Spec....I really don't think (99%) running a receiver pack will make the Club spec work on 1S. Alot of customer trying to do that and I don't see any of those work. Club spec is design for 2S lipo input and I don't want to list all the detail why adding a receive pack onto the receiver will not work on our ESC but work on other brand's ESC.
So far, the only solution I have seen (and tested it myself) is running the TQ CELLS BOOSTER - from Canada (yes, they are the ONLY 1 that works with our speedo) along with the club spec...no need to pull any wire, just follow their diagram and solder their wires onto the ESC and run...
http://www.tqcells.com/TQBOOSTER.htm
If you are talking about something else...please be more specific.
Enforcerman (that is the username) is currently running the club spec with TQ booster at his club and converting the club to use this unit as a spec 12th scale over his area...you can ask here or PM him for more info.
#650
Hi guys, Solara is right about the TQ Cells booster working with the Cirtix Stock Club. We use it in our 1/10 pan car class with 1 cell lipos and the 17.5 brushless and it works great! We have some guys using the Cirtix and some using Tekin and Novak and the Cirtix runs just as good as any of them.
#652
Are you talking about running 1S lipo...? Like on 12th scale..?
Thanks for the reply,
No Booster will be used but a rx battery
No 1s but 2s car.
Will I need to unhook the red wire or leave it be and it won't cause any harm?
Kind regards,
Pizza
#653
#654
ttt
#657
Good luck...
#658
Should throttle be reversed on an Airtronics MX-3x, getting ready to set up. Also a bit confused by set up directions, what is the standard drag brake and ABS setting?
