XRAY XB9E Official Thread - they did it :)
#166
we all hope so
can anyone mesure the battery tray?
I really consider this buggy but need to make sure about the size of lipos needed..
#167
As promised here are a few images with the JConcepts Illuzion Finnisher Xray XB9 Body part #0244 mounted:
Bent
Bent
#168
That tool is a godsend. I replaced all my tekno sct pins with hudy 12mm pins as well last a bit longer and no wear still on the tekno outdrives as well!. I just wish they start allowing 6s softpack in ebuggy here in the states like in europe, nitro bodies look so much better with the flatter side profiles . 2650 to 3300 6s is all I need for a 10 12 min main cooler temps.
#169
Been doing this for years.
Just pop off a camber link, slide the driveshaft out sideways, tilt the car (or as I do, let the driveshaft rest on the setup board) and give it a slight tap.
Takes a few minutes to do the entire buggy
Bent
#170
#172
#173
And there's room to move the battery both in/out and front/rear.
I'll post some body off shots later
Bent
#176
#177
It's pretty firm on the sides but I always use velcro to keep dirt out.
I think I took a picture of the chassis and body with velcro at the track prior to my daughter running hers.
I'll see if I can find it
RTR weight as pictured with no paint on body is 3630g.
That's with:
- Dual IP 7200/80C/7.4V packs.
- Tekin T8 1900KV
- Tekin RX8 Gen2
- Hitec 7950TH
- Futaba R614FS
- Beta V-max tires/rims
- M2C front tower brace
Bent
#178
Yep it's the Finnisher body for the 2012 XB9 Nitro.
That's with:
Bent
That's with:
- Tekin T8 1900KV
- Tekin RX8 Gen2
- Hitec 7950TH
- Futaba R614FS
Bent
#179
That's with:
Bent
That's with:
- Tekin T8 1900KV
- Tekin RX8 Gen2
- Hitec 7950TH
- Futaba R614FS
Bent
Thanks Bent, that's actually heavier then I thought, I'm going to run a 3s system to keep the weight down but I thought with all the carbon that it would be a lot lighter, cheers for your help....
#180
That's with:
Bent
That's with:
- Tekin T8 1900KV
- Tekin RX8 Gen2
- Hitec 7950TH
- Futaba R614FS
Bent
