XRAY XB9E Official Thread - they did it :) >
Like Tree1Likes
Old 07-16-2013, 01:37 PM
  #166
Pulse_'s Avatar
we all hope so
can anyone mesure the battery tray?
I really consider this buggy but need to make sure about the size of lipos needed..
Pulse_ is offline
Old 07-16-2013, 02:00 PM
  #167
BentKa's Avatar
As promised here are a few images with the JConcepts Illuzion Finnisher Xray XB9 Body part #0244 mounted:
Bent
BentKa is offline
Old 07-16-2013, 02:02 PM
  #168
CarlCrocco's Avatar
Trader Rating: 91 (100%+)
Originally Posted by aloksatoor View Post
That tool is a godsend. I replaced all my tekno sct pins with hudy 12mm pins as well last a bit longer and no wear still on the tekno outdrives as well!. I just wish they start allowing 6s softpack in ebuggy here in the states like in europe, nitro bodies look so much better with the flatter side profiles . 2650 to 3300 6s is all I need for a 10 12 min main cooler temps.
The tool is nice, but the mugen one is vastly superior. No hammering involved, and you can change the pins without removing the driveshafts from the car.
CarlCrocco is offline
Old 07-16-2013, 02:11 PM
  #169
BentKa's Avatar
No problem changing the pins without removing the driveshafts from the car with the Hudy tool either.
Been doing this for years.
Just pop off a camber link, slide the driveshaft out sideways, tilt the car (or as I do, let the driveshaft rest on the setup board) and give it a slight tap.
Takes a few minutes to do the entire buggy
Bent
BentKa is offline
Old 07-16-2013, 02:21 PM
  #170
BentKa's Avatar
Originally Posted by Pulse_ View Post
we all hope so
Internal measurements of the battery tray are: 156mm x 55mm x 15mm (L x W x H)
Bent
BentKa is offline
Old 07-16-2013, 03:13 PM
  #171
305M3's Avatar
Trader Rating: 40 (100%+)
Bent
Bent - your pics are always awesome...
305M3 is offline
Old 07-16-2013, 03:20 PM
  #172
BentKa's Avatar
I'll post some body off shots a little later
Bent
BentKa is offline
Old 07-16-2013, 03:27 PM
  #173
Pulse_'s Avatar
Bent
the tray is bigger than mine, I'm sold
and yes your pics look awesome, thanks for taking the time to share them!
crisp and clear
Pulse_ is offline
Old 07-16-2013, 03:33 PM
  #174
BentKa's Avatar
crisp and clear
There's plenty of space for most battery configurations.
And there's room to move the battery both in/out and front/rear.
I'll post some body off shots later
Bent
BentKa is offline
Old 07-16-2013, 03:49 PM
  #175
aloksatoor's Avatar
Trader Rating: 42 (100%+)
@Carl never used the mugen tool before but its cheap! If I did not already have the hudy Id go for it.
aloksatoor is offline
Old 07-16-2013, 03:59 PM
  #176
Jpm1's Avatar
Bent
Great looking car Bent, is that the 2012 nitro body?, is it firm on the sides, or Velcro needed.
What weight was the roller or rtr weights......
Looks very nice
Jpm1 is offline
Old 07-16-2013, 04:15 PM
  #177
BentKa's Avatar
Looks very nice
Yep it's the Finnisher body for the 2012 XB9 Nitro.
It's pretty firm on the sides but I always use velcro to keep dirt out.
I think I took a picture of the chassis and body with velcro at the track prior to my daughter running hers.
I'll see if I can find it
RTR weight as pictured with no paint on body is 3630g.
That's with:
  • Dual IP 7200/80C/7.4V packs.
  • Tekin T8 1900KV
  • Tekin RX8 Gen2
  • Hitec 7950TH
  • Futaba R614FS
  • Beta V-max tires/rims
  • M2C front tower brace
Bent
BentKa is offline
Old 07-16-2013, 04:53 PM
  #178
EGA-0007's Avatar
That's with:
  • Tekin T8 1900KV
  • Tekin RX8 Gen2
  • Hitec 7950TH
  • Futaba R614FS
Bent
Your car is AWESOME!!! i'm in love with it, i've always loved the finisher body for the Xray but i've got to get one now, just waiting on the official release and see what body Xray comes up with.
EGA-0007 is offline
Old 07-16-2013, 04:59 PM
  #179
Jpm1's Avatar
That's with:
  • Tekin T8 1900KV
  • Tekin RX8 Gen2
  • Hitec 7950TH
  • Futaba R614FS
Bent
Thanks Bent, that's actually heavier then I thought, I'm going to run a 3s system to keep the weight down but I thought with all the carbon that it would be a lot lighter, cheers for your help....
Jpm1 is offline
Old 07-16-2013, 05:00 PM
  #180
aloksatoor's Avatar
That's with:
  • Tekin T8 1900KV
  • Tekin RX8 Gen2
  • Hitec 7950TH
  • Futaba R614FS
Bent
Woah thats heavy. My 808 nitro conversion was around 7.5 lbs rtr this is 8!
